Quick Help - 5100 Snap Ring Position Question
That spacer is not 1/4" from what I can see in the picture. The bolt holding the shock in place is a 10 mm diameter. That spacer is at least that thick. I'm thinking you have a 1/2" spacer and that equates to a 1" lift. Then you had the shocks at their 1.8" setting. That's about 2.8" of lift. Your setup moved the A arms into an angle that provides less mechanical leverage on the spring. "pre-load" schme-load. That aint the issue here.
It looks like about 3/8th to me. Either way the problem could be that his suspension is topping out quicker on bumps when the tires leave the ground. 5100 with compressed springs and spacers do not go good on these trucks seems to be the consensus. Instead of lowering the spring perch he should have removed that spacer. The suspension was not designed for a longer strut.
I had mine done by a local shop and had the snap ring set in the highest position.......for some reason when I got the truck back it didn't seem as high as I thought it should be. It was cold, snowy and just miserable for the next few weeks so I thought nothing of it. Once the weather cleared up a bit I took a look at my front shocks and noticed that the shop must have moved the snap ring to another position. Kinda pissed me off but the shop didn't charge me because it's a family friend. So I am baffled at what level my truck is at.... I took a pic and was wondering if anyone else with the same front shocks could take pics of the snap ring locations so I don't have to disassemble the front end again. Any help would be greatly appreciated. It looks to me like I am down one notch from the highest setting which would be 1.26"
Cliff14Denali,
I just installed the 5100's on my 2014 Silverado LTZ. It looks like your snap ring is set in the second position from the top. If it was in the top position you would not be able to see the groove.
Cliff14Denali,
I'm thinking he is set on the bottom or second to bottom. I have mine on the second from the top and I cannot see any slots above at all. I can only see one slot below the spring seat.
It is hard to tell. I was looking at mine and with it in the highest setting, there are no grooves above the spring seat. With his you can see one groove so it looked like it might be down one.
+1
    needafix
    needafix
  • Who's Online   6 Members, 0 Anonymous, 533 Guests (See full list)
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
