2003 1500HD Instrument cluster
I have an issue with my instrument cluster where it basically shuts down. no gauges, warning lights etc. At first I could tap on it and it would come back but it's gotten progressively worse. I have resoldered every connection on it. I have connected it as just the circuit board so I could tap on individual components to isolate the issue but it's just pretty random when it decides to come back on.
I've gotten to the point where I think I might have to replace it. The question is: Can I get one from a scrap yard? Will I need to go to a dealer for reprogramming after that and does anyone know what they would charge for that?
I will probably call the dealer today and ask them, but I thought I would research first in case they throw me some BS.
Thanks,
The odometer reading is stored in the cluster. So if you want the mileage to be correct, you'll have to get it programmed.
Cluster is generally $200ish and programming is $50-$75. I replaced the cluster in my '01 Burb because of the same issue - took the opportunity to upgrade to the HD cluster to have the trans temp gauge. The eBay seller programmed the mileage for me at no charge, but this was about 8 years ago, when there was a lot more demand.
Im sure the odometer is not stored in the cluster. I changed mine on my 99 and bit showed the correct mileage. Just get a used ome at a wrecker and you should be good to go. The owbi got for the 99 was from a 02
Scrap yard cluster will be just as problematic. Just about every cluster in our series of trucks will fail. Not maybe, but will fail. There are several places on line that rebuild them. All they do is replace the 6 stepper motors. Save yourself the aggrivation and have it fixed.
It's not a stepper motor problem
Agreed not a stepper motor problem. I should have read the original post a little better. If you pull one from a salvage yard, expect to have stepper motor problems. GM extended the warranty on the gauge clusters. Mine bit the dust right after the extended warranty expired. There are shops on line that specialize in the repair of GM clusters. I think Bob's Speedometer does a rebuild for $99.00.
About 2 years ago, I had the stepper motor issue and replaced the motor from ebay for about $10. I've worked on electronics most of my life and that type of repair is not an issue for me. I've been over this thing resoldering connections but not getting it.
We have had the same problem on the 2000 GMC. What worked for us is taking the pins out of the harness connector to the cluster and re-squeezing them and re-installing them. Ours was the ground pin. Search you tube for the repair.
Good luck,
Andy
Good luck,
Andy
That sounds promising. I have wiggled the connector and it didn't come back on but I've seen bad connectors like that. I'll give it a try.
" I've worked on electronics most of my life and that type of repair is not an issue for me. I've been over this thing resoldering connections but not getting it. "
Another place to check. On the board, check these two components (resistors?) and re-flow the connection. This is just to the upper right of the speedometer stepper motor. This was a problem on my 03 Tahoe.
Andy
I am on my 2nd cluster... this is normal. Wrecking yards might have them, but GM has to program your mileage and hours on it. Sucks. wrecking yard parts are used just as yours and you will be parting with more money if you buy used... then a few months later buying GM. Save money, just buy GM.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
