Plasti dipping parts on your Truck
I put some on my sons truck when it first came available last summer and has lasted through 2 Texas Summer's of being parked outside 24/7
  • Replies 203
Any pics?
- Mike
IG: @BlackPearl_Edition
any photo's of emblem's / letter's - Plastic dip ??? How to do the Z71 emblem on the doors ????
1 - tape off roughly. Doesnt have to be perfect since it peels right off.
2 - spray 4-5 coats with 10 mins dry time between coats.
3 -pull off tape and remaining plasti-dip around the emblem. It'll pull right off the paint like latex.
4 - done. Sit back and enjoy your new look.
It is really that easy.
thank you. add that to the list.
How well does the shine hold up? To me dip kinda seems to fade after a few months, granted this is in Louisiana sun and its already matte so it's hard to tell. But curious how the gloss series auto dips hold up. Thinking of making my grille a gloss black and wouldn't mind trying this
- Mike
I used dip glossifier for a shiney black it worked great to make a gloss look instead of matte.
if you use an armorall style protectant on the dip when cure it gives it a nice shine and uv protection as well as makes it smoother. Mine has held up many many months and retained look.
^^just like this
i did mine last weekend...
this is what i did when i did my tailgate logo...
^^just like this
thank you. only emblem's are the bowtie (black) and the Z71 on doors - midnight edition. thinking the Z71 would look good black ?????
you do not even have to mask and cover that much area. that is way overkill just to dip the rear bowtie but hey i was paranoid my first time. 1 sheet of newspaper would be plenty any over spray rubs right off and wont stick to an area not preped and perfectly clean.
I just used a large trash bag. Cut it open and taped it over the area being sprayed like bc-Chris did. Cut it open around the emblem and you're good. I wouldn't mask off less though. Overspray can get everywhere!!!
agreed!!!
when i did the "silverado" on my doors and tailgate i think i just used 2 strips of 2" wide painters tape. any over spray came off super quick with a tiny bit of goo gone and a microfiber towel
agreed!!!
How does it stand-up to car washes (Brush) ???
so far no problem at all!
i was very "yea right" when i first heard of plasti dip but i can honestly say that i'm really impressed with the stuff!
^^just like this
This looks fantastic. Did you use any kind of clear coat afterwards? Also, does the dip hold up over time or will it peel like paint?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
