Plasti dipping parts on your Truck
My white dipped bow ties are starting to look a little dingy after a month, with specks of road grime getting imbedded in the dip.
Best so far to clean them is Windex.
I'm wondering if I should paint over them with spray paint...
Any suggestions for white bow ties that will stay looking good with minimal maintenance?
  • Replies 203
Anyone ever spray their chrome door molding? Thoughts?
I did my window trim about a year ago, haven't had any problems with it
Anyone got any pics of and irridium metallic truck with black dipped emblems/badges?? I've looked through most of the threads can't find what im looking for. Thanks.
Sent from my Note 4
Sent from my Note 4
I debadged mine but I ended up using vinyl to cover the bowties. Also replaced the z71 sticker with an all black version.
Looks good, thanks!!
Sent from my Note 4
Check out Echavez, that man has everything dipped [emoji106]
True paint for minimal to no maintenance. If you want to stay dipped, then respray and look at getting dip coat. Just wipe it on whenever you wash the truck and it's supposed to help tremendously. Don't know how much it actually does
Here are some pictures of my front bumper and grille plasti dipped black (4 coats).
To remove the plasti dip I purchased a bottle of dip dissolve from dipyourcar.com. This illiviated any headache I was going to have with getting it off the honey comb grille.
when you dipped ur front bumper did u remove the bumper? did u also do the back? i want to do this
First, yes I dipped both bumpers, grille and chrome molding. To this I did not remove anything from my vehicle. To do the bumpers i ran a single piece of painters tape along the areas that I did not want dip on. Then i came back with newspaper to cover areas from over spray. Just make sure when you spray the dip that you get the edges good so you can easily peel off the excess. By doing so you will get extremely clean lines where the chrome meets the plasti on the rear bumper and where it meets the paint in the front. Now for the grille I did remove the cover on top under the hood and insert pieces of cardboard to protect my radiator from over spray.
Sent from my SM-G900P using Tapatalk
thankyou.
  • 9 months later...
F333A945-CA8F-450C-8F12-7FA11B42E110_zps
1AD9F689-95AC-4CB0-A760-3CBC9868C43D_zps
All emblems have been plastidipped to match and same with grille surround. Emblem black parts are semigloss black rustoleum paint though and all emblems were clear coated so they'll last longer
Have you had any issues with the parking sensors and your bull bar?
Yes, the bullbar makes the sensors freak out so I put sensors in the bullbar. Honestly I have yet to wire them in correctly as Ive become so accustomed to not having them that I always forget to fix the wiring whenever I have the time
This may have been brought up in previous posts but if not here is what I have been using instead of Plasti. It sprays so much nicer and is 10X more durable then plasti. I will never go back to using Plasti again. http://www.autodip.com/
How well does the shine hold up? To me dip kinda seems to fade after a few months, granted this is in Louisiana sun and its already matte so it's hard to tell. But curious how the gloss series auto dips hold up. Thinking of making my grille a gloss black and wouldn't mind trying this
- Mike
IG: @BlackPearl_Edition
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
