What is the real info on 22s
That's a cool calculator, unfortunately it's not quite accurate. It is treating the tires as rigid bodies failing to account for the smaller rolling radius of the tire due to the weight of the vehicle. For the best numbers, it's better to go to the tire's spec chart.
For example here you can see the stock SR-A's are rated at 655 revs/mile. http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+SR-A
I understand that, but for a quick comparison, it's good enough.
  • Replies 40
Maybe some of you guys can help.
I'm in the hunt for a 22" wheel and what I want is a bit specific, kind of outside the mainstream. I want a 22x10.5-11.5" with offset around +15 mm to +30 mm. I'm planning to run a stretched 285/45 or maybe 305/40 depending on width. No chrome-plated and black finishes, but silver, machined, PVD (chrome and black chrome), other powdercoated colors, and polished finishes are ok.
Some brands I've looked are Centerline California Smoothie (only 9" width), MHT, Fuel, Dubz, American Racing, Enkei, Foose, Intro, Niche, Konig, Circle Racing, Boyd (spendy), Raceline, Mobsteel Detroit Steel Wheels, the trio 2-spoke wheels (Vision, Status, and one more I can't remember), very nice yet very expensive CCW-HRE-Forgeline-others, Lenso, and brands offered by Tire Rack and Discount Tire.
What else should I look?
Thanks.
basic formula below... I run this in excel... so calculate your current size. then do your new size. if the match (or really close, no need to recalibrate the speedo.
The example below is for my race truck.
tire diameter = 2 x section width x aspect ratio / 2540 + rim diameter
Width Aspect Ratio Rim Diameter Tire Diameter
225 60 15 25.63
HOOSilvy, which wheel code/product is that? I really like them as well! I think they would look great on my Silver CC 'ado.
Thinking of putting these on my wife's Black CC LTZ. What do you guys think?
I'm thinking of those for my truck only silver and chrome. They're a great looking wheel.
Here you go!
The ride is slightly more firm and there is increased road noise over the Michelins I had on the 20" wheels. I can probably get use to that, but I was spoiled with the Mich.
Pic are dark, but I'll try to get better ones.
They are 22 x 9 OE Reproductions off EBay. I love the look. Would be unbelievable on a black truck. They are replicas of CK163. And the best news? Half the cost of GM.
I just bought a sierra with these wheels on it and I am really surprised how well this tire and wheel comb rides. Not to mention that I think they look great on my truck!
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
