2015 6.0 Muffler
hey how about some sound clips
I'd be happy to if anyone can give me some advice as to how. I can't even upload images these days without being told they are too large, even though they are just average cell phone photos.
  • Replies 39
ok,i just put a video link up here for the noise my truck is making. i put the video on you tube and then did a link from the post to see it.
  • 6 months later...
Only issue is the driver side tailpipe section that goes over the rear axle definitely makes contact with the spare tire. Spent a solid hour on adjustments to make sure everything was perfectly lined up and unless I wanted the two exhaust tips to be completely uneven, I couldn't make it so the exhaust didn't touch the spare.
Sounds great, BTW!
I know this is an old post but I wanted to let you know that if you haven't figured this out yet all you have to do is lower the spare a bit and slide it to the passenger side. Right up next to the plastic heat shield is fine. Then tighten it back up. You will have all the clearance you need then.
-Eli
  • 4 months later...
I've seen a lot of threads advocating for the super 40 on the 6.0 and also some advocating for the 50 series HD. Are there any advantages/disadvantages to either? which one's louder? they're both 3.5" in and out, and both come in stainless steel so just looking for some insight on that!
do you happen to have the part # for the Magnaflow used?
12909
That's the one I ended up using
Sent from my STH100-1 using Tapatalk
for all those looking for sound clips, just youtube the part number and silverado (1500,2500,etc.) should pop right up.
did you have to add any piping with the install? Mine comes in wednesday, and i wanna make sure I have everything!
I'll have to have a look, I had a muffler shop just cut out the factory muffler and weld in the MagnaFlow, I think they had to add a small section
Those are perfect! thank you!
    DNL going
    DNL going
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
