Has there been any updates to the Intellink
And you guys are getting this piece updated?
That's what the bulletin is pertaining to. All software is in the Head Unit as that controls everything. So, that's what gets updated.
  • Replies 71
You may want to sit down and re read about this system, you are WAY off.
You've gone from "What's a head unit" to a proverbial expert in the system? Yes, it's very different, but when a question like yours comes along, the most direct way to understand is to see the main control piece as where everything lives.
No one is having the head unit -replaced-, they're getting software updates for certain modules. What gets updated is directly related to whether or not the specific modules are in your truck (for a particular bulletin) and what version of the software you're currently on.
Yes I went from "what is a head unit" because I was trying to understand what you guys are calling a head unit. These trucks do not have a "head unit" if you are referring to the radio controls (buttons) there is no "update" for that, or are you referring to the display, still no update for those either, or maybe you are referring to the Tuner (radio) which is the so called brains of the operation and there are updates for that depending if you have a 14, 15, or 15i as to what software you'll have, or could you be talking about the HMI (human machine interface) which would only be present in IO4, IO5, and IO6 systems and that also has updates and will also depend on if you have 14, 15, or 15i. In this system there is a MOST bus for communication between the modules that along with the Tuner and HMI if equipped will include a Media Disc Player(TG5), and AMP(UQA, UQS), and the IPC (UDD) the controls and display are not on this bus tho and talk to the HMI and Tuner on a LIN bus and the display gets its feed via a LVDS cable. So what i am saying is this whole thread is useless to anyone going to a dealer for and update. If you go in and ask for your "head unit" to be updated they are going to have no idea what the hell you are talking about.
I would also like to point out that when you go to your dealer and they hook their "machine" to your truck it is almost always going to tell them they will be installing the same software that is already there, which is partially true. There are in some modules 20+ software number lines, and most update will only change 1 or 2 of those the rest will be staying the same so in turn it tells you it is rewriting the same software
Hell Ya!....... What He said.^
If you have a specific problem then ask the dealer to fix it.
Maybe next time, instead of using the passive-aggressive approach, you could just add some color commentary about how the system differs from aftermarket systems that use a true head unit and operate remote devices.
I took mine in to get checked and they said it was current. I asked how that was possible if the release came out in feb/march but my truck was built in january. I got on video the touch screen not working (me touching all the icons) and nothing happening till I restarted the truck.
service said when I bring my truck in for the head lights they will keep the truck and work with who ever they work with (some engineer) to try to get the issues resolved
Mine never did this prior to the update... frustrating.
For what it's worth, it's an iPod touch (not an iPhone), but it's the Gen I model. I have a Gen 2 or Gen 3 that I'm going to try and see if it's any different but I doubt it will be.
Mine does this too with a 160GB iPod Classic. I'll have to check to see what version the Intellilink is on, I've never had it updated, I bought the truck in November 2014. It drives me bonkers. My older, 60GB iPod does NOT do this, when it works (half the time the system doesn't recognize it's plugged in... but when it DOES recognize it, it works fine).
I've had the most success with Bluetooth audio from my iPhone, that always seems to work when I try it. 2nd in line would be a basic 128GB USB thumbdrive I loaded up and stuck in the truck... that works about 80% of the time (other 20% it doesn't recognize it's there). My older 60GB iPod works about 50% of the time, and the newer 160 even less.
I've got a $100 basic Alpine unit in my other car that's 6 years old and works flawlessly with both iPods. Both also work just fine in my wife's $24k Volkswagen. Disappointing that this $55k truck can't figure it out.
I've done some additional testing and verified that it also does it with my iPhone 6 with iOS 8.3 (USB-connected, not bluetooth). So, it's definitely related to the USB interface. And, it appears to also be related to the update as I didn't have this issue before the update. I will let my dealer know and see if he can locate any additional bulletins, updates, etc.
Hey hurricanoday,
Although you're having some issues with the touchscreen in your truck, it's good you've brought this to your dealer's attention. Feel free to keep us posted when you go back for your headlights. If you'd like for us to follow up with them just send us a PM. We'll be on the lookout for any updates.
Sincerely,
Eddie A.
GM Customer Care
Not sure I am reading your concerns correctly but if I am this system requires you to press the media button to switch to a USB connected device. It will not switch to it when plugged in automatically like the old systems did
No, it's different. The quoted post below highlights what I'm running into.
I've driven a bit with the new software and have observed a couple of changes - one good, two bad. All deal with USB audio.
BEFORE: Setting my iPod as the input source and choosing "Shuffle" mode, the first 3-4 seconds of the next song will play while the system is initiating the search for a new song to play at the end of a track.
AFTER: Shuffle mode appears to work very cleanly with no "running into the next track" before switching to the next track it will play.
BEFORE: No issue
AFTER: When switching to the iPod from a different source, the display shows all of the pertinent information for the track it's playing. This information remains on the screen regardless of what track the iPod plays next. The only way to get it to update is to switch to a different audio source and then come back to the iPod. I have also observed that switching FROM the iPod to a different source will stop the iPod audio immediately but requires about a 5-7 second delay before the other input will switch on (I typically switch to the radio).
BEFORE: No issue
AFTER: The first two seconds of the track are scratchy / static-y if there is album art for the track being played. The scratchiness occurs during the time that the album art is being transferred to the head unit for display.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,872 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
