Bought new All Terrain, want better tires.
I am trading in my old Dodge Ram and picking up a new 2015 GMC All Terrain with 18" rims tomorrow and I know the stock 265/65/18 SR-A's are terrible tires. Looking to replace them asap with a decent A/T tire. I assume I can't go to a much taller tire without having ECU issues? I am thinking either going with 285/60/18 Cooper Zeon LTZ, 265/65/18 Duratracs, or maybe the Duratrac in a little bigger at 275/65/18? All 3 seem to be within 1/2" of each other in diameter. Any opinions or other recommendations?
Thanks.
I have the SR-A's and they aren't as bad as some people make them out to be. They did decent in the winter for me and got me through a foot or more of snow. Haven't tested them in the mud though.
I do know that they have a horrible tread life. Once mine wear out I'm going with Some BFGoodrich KO2's and levelling my truck at the same time.
If you don't want to bother with leveling, 275/65/18 fits, no prob. Cooper ATP is what I went with.
Was just looking at the BFG KO2's. Look great! I have had the old KO's on a couple trucks and they were good tires. I am not going to be levelling the truck, 275/65/18 would be great. Would there be any issues with the slightly bigger size? Seems like if you go too much bigger diameter there are issues multiple issues unless you reprogram the ecu?
Only issue is the speedo will be off, that I am aware of. Some have done 285/65 or 275/70 if you want taller.
You won't have any issues with the 275/65/18 that's what I was running on mine when it was stock I had the BFG KO's. Speedo was off by 1.5 mph put 8k miles on it without any issues. Then I went with the leveling kit and 33's and ended up calibrating the speedo for the 33's and everything works as it should.
Love my duratracs as does my dad on his denali.
This is a pic in a damp grass field with the sr-a tires.
Thanks for the info guys, pretty sure I will be going with 275/65/18 BFG KO2's. Diameter on these is 32", only 1/2" taller than my stock SRA's and pretty well the same as the stock tires on the optional 20" rims(31.9").
I have almost 10k on my 285/65r18 KO2s and I couldn't me more pleased. They are very quiet on the highway and they were fantastic this winter in snow and ice.
The only downfall is that the 18" sizes are 10 ply E rated (not really a downfall). Great for towing and preventing flats, but they are heavy and ride rougher than the stockers.
From what I have been reading the KO2's are a better tire than Duratracs. I have had the old BFG KO's on 2 older GMC trucks and my Ram had Cooper Zeon LTZ's. Never been a fan of the garbage OEM tires. This is my first truck with all the computer gizmos like traction control, fuel management etc. Just don't want to affect the operation of those systems.
Had the ko2 since November 18,000 miles love them they did awesome in the snow... just wish i wait and got 275/65/20.
I almost got the BFGs but found a good deal on take-off SR-As.
Frankly, I came from Bridgestone HTs.. so.. to me the SRA is great! :lol:
Take some pics when you get your ko2s on! I love all terrains and with nice aggressive tires you should have a really good look and a highly functional truck.
love duratracs but they are a bit noisy, traction with the sra's was not bad but they vibrated when cold like an old bias ply tire after a miles or so it went away. They vibrated at 70 mph and it just wasn't the look I wanted for my "all terrain". The duratracs have no vibration at all I have had them up to 85mph
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
