2015 silverado changes corsa sound???
i just did youtube searches and found the best comparison to what i hear on my truck is corsa touring on a yukon 6.0l
sounds exactly like mine
I just looked it up, not that impressive to me, most guys on here are running the sport. But for the price you paid, I'm pretty sure the tip alone is worth somewhere around that much.
yes i agree .... for the price its worth it but like i said it is very mellow i woud have liked it to be a little louder more aggresive
I checked the vid. Looked good. My tastes run toward the quieter side.animated-smileys-vehicles-0301_zpskodiix
this is definitely a mild setup however i will say this morning i started my truck and it is more aggresive than yesterday!
it stays very mild while driving and then when the truck accelerates it opens up a little more....
Right on! I noticed mine seems to be louder after breaking it in a bit too. Increasing air flow into the engine also helped, I put in a dry filter off ebay that cost $20 and I would say its just as good as the expensive brand names.
ill look into that!!!
do you notice any performance gains acceleration feels different. more responsive
i wonder how good the mpgs change
No real difference in performance, but I got 10.7l/100km on the way home after buying it which is about 22-23mpg. I thought that was pretty good.
200 mile update!!!!!!
truck sounds great! definitely got a little more aggrisve as i put more miles on.
a side note to add.....i will never go to lous custom exhaust ever again in my life!!!!! their work was horrible. after i crawled under the truck and saw what they did i immediately called them up and called a professional shop in the area. the new shop is RD exhaust in billerica mass. great guy to deal with! they took off the tail pipe from the muffler back and i could see they just stuck 2.5 tubing unbent from hanger to hanger of the factory setup leaving pieces of the factory tailpipe in place and them welding the hell out of the pipe. this was the worst quality work ive ever seen in the automotive world. i will post a picture. soon.
they also redid the tip in correct spot and made sure it was level.....
i will never use lous custom exhaust again they do not take pride in their work.
Most places will just weld in pieces when removing components. Unless you specifically ask them to fab you up a new cat back.
ohhh i told him i wanted one solid 3 inch tailpipe from the muffler back!
now that i have this high quality setup im very happy with the setup! it has much more bark to it!
Here is my truck with Corsa....its sounds pretty aggressive when you get on it. I really like...
Skip to 57 seconds
Been meaning to get a take off and drive by video too. Haven't had a chance.
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
