Stabilitrac Issue from lift or tires
Well then fine sir, I concede.
That is actually incorrect. Stabilitrac and traction control are actually two different products but piggy back off each other. Traction control is designed to keep you from spinning the tires where as stabilitrac is designed to apply the brakes to each wheel at different intervals to straighten the truck. The idea is to help prevent roll overs and I believe is also now a government standard.
  • Replies 149
Sorry, I probably came off like an ass hat lol. I have a tenancy to do that and its not intended at all.
NAh I didn't take it like that at all. Also even if I did think you did it wouldn't matter. To old to get worked up over simple things.
I had this issue show up 1 time turning hard left. I crawled my fat ass under the truck and found that I had a snug sensor wire under full lock and made adjustments. Issue has not repeated... It's been 4 weeks.
I just looked at my sensor wires the other day. They are pretty tight, no slack. Also noticed they're not snapped in the little holes on the upper arms anymore. There's no slack for them to be snapped in there.
Went and looked and mine are not clipped with that one plastic clip either but the wire isn't tight at all and seems to be able to extend with articulation of UCA. I don't know guess I'll keep an eye on it.
Got my front coilovers lowered an inch and aligned by a Bds authorized shop and so far so good no more stabilitrack coming on. I tried hard lefts and rights and its seems the alignment was the issue
That is awesome, I have my fingers crossed for you that it doesn't return. And by the way thanks to you posting pics of your good looking truck I was inspired enough to go the same route. So my hats off to you.
Any idea what alignments they went by? By factory or by BDS?
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 862 Guests (See full list)
