Factory Brake Controller - After the fact with Tow pkg
The one WITH the hitch...It is a truck after all. I have a small hitch on my Honda accord for my wife's bike rack and a class 5 on my 2015i GMC 2500 HD and I use it.
Sierra Boy
  • Replies 40
If you saw two used trucks (same trucks and mileage & equipment in all ways) on the dealership lot with one with a trailer hitch and the other without a trailer hitch - which one would you buy or pay a little more?
I would buy the one with the hitch since I would have put one on it anyways if it didn't have one. I doubt not having a hitch would help the asking price. Plus with all of the trucks that come standard with a hitch there's probably more people that don't use the hitch. Unless someone at the dealership personally knew the person that traded the truck in then there's not much to know how often the truck was used for towing and you can't go around assuming just because it had a hitch that they used it to tow everyday.
I guess we come from two different schools. Buying second hand is always a risk if you don't know the previous owner or how it was used. Mileage may also be a consideration but the high cost to repair an engine or transmission etc. is a big factor for me. If the truck never had a hitch, I would purchase that one and put on a hitch and do the wiring for about $200 to $300 to deal with this unknown. Usually the hitch is a bolt on and it only needs a pigtail (because the wiring at least on my 2008 was already there from the factory). Especially if you just want it for decoration and don't have any plans to use it. Trucks don't come standard (need trailer package for additional cost - $770) with a hitch and doesn't have any resale value to it in my opinion. This is based on the fact I always got better money on my older trucks without a hitch.
  • 4 weeks later...
OK, someone smarter than us needs to figure out out how to add the factory brake controller. Common....
Lots of smart have looked at it, the problem is some of the chassis wiring harness is not the same, you are missing the dash controller and that harness as well. then the biggie is getting the BCM reflashed to turn on the brake controller function. That is the part that is a no go as GM now only allows the dealers to flash modules with the exact calibration that is tied to your VIN for that module, the loop hole of substituting another VIN has been removed.
If I was to guess you would spend well over $1k in parts, not including labor and still not be able to use the factory controller yet when the factory controller is only an $230 option.
As said it is a lot cheaper to go aftermarket and they operate the same way the factory one does.
IT CAN NOT BE ADDED. There's nothing to figure out, it just can't be done.
The answer is simple, buy a truck that comes with the controller, that's it.
Sent from my crappy iPhone 6
using Tapatalk
I know... thanks. I like the features the P3 has. big question is where do you mount it.... probably end up on the knee area.
Are you sure the trailer for boats you are looking at even use a brake controller? Most all boat trailers including triple axles I've seen have surge brakes.
If I saw a used truck without a hitch, I'd be suspicious. Wha' are they hiding? Gotta have me hitch. And, those Prodigy brake controllers work great! For anything over 2,000 pounds, ye MUST have trailer brakes. If ye think going is hard, just try stopping'er. That'll raise ye hackles.
^ I want Electric Discs on my boat trailer. We'll see what boat/trailer combo I end up with then go from there. But most of the 25-30' boats I'm looking at all have double axle, some tripple axle. All have electric drums, some nicer one have electric discs.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 267 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
