How much weight can the my lift gate handle?
I bought a RZR, as of now I do not have a trailer. The weight of it is just under 1,000lbs. I read on some of RZR forums some concerns about ability of the lift gate to handle to weight of the rear wheels. I will won't be carrying it often in the bed, but when I do, I will be driving nearly 3 hrs. I would put 2X's under the wheels, but the last thing I want to happen is have the lift gate to break under the load.
I saw this video using an LA Guard dog to secure the vehicle. It looks like it will keep the vehicle secure, but the lift gate looks to be taking a beating.
Completely new to this, so I am not sure if this is a real concern of if some are being hyper cautious. Thoughts?
Thanks
I know your asking about the tailgate but do you have the extra total capacity to carry 1000 lbs? Personally I wouldn't do it,that is a lot weight on the gate while moving and a failure will be real bad. You can get a trailer for under 1000 bucks.
Not sure which model you bought but the plain jane trail 900 is close to 1200 lbs. dry without any accessories.
Thanks
Get yourself some tailgate support bars from D.G. manufacturing. www.dgmtailgatesupport.com
Thanks High Country. I have a 2500 so I am not worried about the overall weight in the bed. Just focused on the lift gate. I have a Rzr 570 which is just under 1,000. As I said I am new to this and I see pictures everywhere with ATV/UTVs in beds but all that bouncing around on the lift gate makes me nervous
Not all the weight will ever be on the tailgate at one time. So you should be fine. I used to haul my motorcycle in the bed of my truck. The rear wheel would always be on the tailgate.
If you are really worried about the tailgate, you can invest in stronger support cables and you can also put a sheet of ply wood in the bed, under your 4 wheeler. This will distribute more of the weight evenly
Get a 4'x8' sheet of 3/4" PT plywood and call it a day!
How does this help? Putting a flexible piece of wood underneath the load won't carry any appreciable amount of that load back into the bed. The only way to accomplish what you're alluding to would be to create a slide-out type of platform that mounts inside the bed and "hovers" completely above the tailgate.
When you're loading a vehicle like this, the front wheels will carry a portion of the load, transfer it directly to the tailgate (you don't have a Lift Gate - those are on commercial delivery trucks), then transfer into the bed. When the rear wheels land on the tailgate, THAT portion of the load is resting on it.
If you're able to, you could get weight readings for the front axle and the rear axle separately from each other to know how much weight each of them carries. The higher one should definitely be -inside- the bed during transport, and a portion of the total load carried will include your weight.
Except when your driving it up the ramp, then all the weight is on the end of the gate, loading and unloading will be the most stressful part of the deal and then you need to add yourself into the total weight.
Not really true, but this is an important thing to think about.
While the ACTUAL weight is never entirely on the gate (a portion is transmitted directly to the ground through the ramp), the fact that the weight is actually applied in a way that LEVERAGE comes into play is important. So, the tailgate -could- end up having to support more weight than the vehicle/driver in the first place.
I don't think there's anything to worry about. From what I understand, they're just steel braided cables with a coating to protect from the weather.
If you really that worried then just buy the tailgate support that was mentioned above. It looks like they're just simple flat bars that have ends made to latch into each end where the tailgate latches when up.
This about sums up what most have said, well maybe one or two of us.
Q. I have a side-by-side (UTV) that is too long to fit in the back of my truck without leaving the back tires on the tailgate. Can my tailgate handle the weight when transporting it?
A. We think you would be taking a big risk since the dynamic tension in the tailgate cables caused by uneven road surfaces could easily be several times the static tension. If transporting with a load on your tailgate is your only option then drive as if you were hauling a tub of nitroglycerin. We would have liked to have measured the dynamic tailgate cable tensions generated when trucks were driven down bumpy roads with various loads resting on the tailgate, but I could not find anyone willing to monitor the tension gauge while I drove. All of our tension measurements were taken with the vehicle being loaded in various positions, either partially or fully on the loading ramps and/or pickup bed/tailgate.
Wouldn't take much to build a thin platform to drive the UV on in the bed. Maybe 4 - 2x4's turned on their side screwed to the plywood, would be like an I-beam setup. Should hold the weight just fine.
Thanks for pointing these out. I am going to go with these.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
