Bad bad day...dam theives!
Suckers got me three weeks ago and a guy down the street, three days later a suburban and another 1500 got theirs stolen as well.
  • Replies 83
I'm looking at about 4500$ to get my setup back on my truck
Sent from my HTC6525LVW using Tapatalk
I'm just a little confused... I totally understand getting tired of seeing your truck on blocks.. but you went out and bought rims and tires. So what did the insurance give you? New oem rims and those bigger tires? Or a check?
Yeah I wouldn't put any kind of stocks back on.. you will get robbed again. Texas loves stock rims
I went out and purchased wheels and tires while I waited for the insurance check
Dam sorry to hear that.
Are you in Houston?
I always loved the signs along property boundaries that said "Trespassers will be shot, survivors will be prosecuted".
My favorite is " Trespassers will be shot, survivors will be shot again."
Camera's work as a deterent.
I have them up on my place and things happen on both sides of my place but they always bypass my place.
The only issue is the police keep coming for Video but I'm glad to help. Ha Ha.
wow...so thankful i have garage to park in at night at home...and behind a gated fence at work... :crossfingers:
That sucks. Looks like they just left yours on the ground too.
I think I'd cry if I walked out to that.
Such a terrible feeling.
Yeah bro it sucks and what's sucks more is that insurance didn't give me what they're worth
Were they OEM? If so, you should have gotten at least close to 100% replacement on them minus your deductible.
"""""Getting all lug nuts locking gorilla nuts which the outside sleeve will spin so they can't use socket method"""
I have these locking nuts on my AT wheels. Seem to be better... but not really sure?
I received half the value of new and yes they were oem. But whatever, after the aftermarket I'm getting ill be breaking even.
are these locks on their website? A buddy and I were talking about how there should be locks like that to make it harder on thieves. I'll have to look into it.
Part number: http://www.amazon.com/Gorilla-Automotive-61641-Acorn-Thread/dp/B002801NI8/ref=pd_sim_263_1?ie=UTF8&refRID=1NV54V5ZKQHRXV4DPYWN&dpSrc=sims&dpST=_AC_UL320_SR320%2C320_
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 1 Anonymous, 841 Guests (See full list)
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
