Tailgate rubbing on bed pan
iceman1959
I have a 2014 Silverado and have an issue with the bottom inside tailgate rubbing on the box bed pan.
I have went through my subdivision and have found 2 others with the exact same problem. I was wondering if there was others and if there is a fix for this.
My guess, working for GM and building these trucks from 1994 till I retired in 2007, is that there is no fix and that the parts were either not properly positioned or the fixture was not set correctly. For that I feel these boxes and tailgates should be replaced.
Replace the box and tailgate? Doesn't that seem a little extreme? They will probably make some adjustments and hit it with some touch up paint.
There are no adjustments that can be made. I built these till 2007. So now do they reform the metal and a quick touch up. I don't think so.
I'm looking for others. Found 2 just in my Subdivision.
After contacting GM about the issue they have decided to make me another tailgate but it will be a little thinner.
Apparently they had an issue and thought they got all the bad boxes. Unfortunately there were a few that got through the system.
So the only solution is for a thinner tailgate this will supposedly stop the rubbing.
So the only solution is for a thinner tailgate this will supposedly stop the rubbing.I
I have the same problem how did you get the new tail gate?
Took it to my dealership were I bought the truck and told the body shop I wanted this corrected. There is no repair for this and GM thought they caught them all.
So the only correction that the engineer could see as of now is to try a thinner tail gait which I said lets try.
Thinner as in inside to outside or thinner as in bottom to top? Seems like another solution would be to slight move the hinge point of the tailgate or the posts it hinges on.
Yes, there is a fix for this. It is called Quality Control. Something GM abandoned a long time ago.
And there is no excuse for this. Proper quality control during part manufacturing, as well as final vehicle assembly should ensure that even if an out of spec part finds its way into the system (=failure of quality control at part level), such a part should never be installed on a vehicle (=failure at the assembly level). Finally, even if it is, the final quality control check should never permit a vehicle like this to leave factory. GM quality control failed on all three levels here. Which tells me that it is totally inadequate.
Yes working there they must have had a crash and a fixture was moved out of position. This happens and most of the time it is immediately corrected but in this incident apparently a few got through the system before the bad parts were caught. Once caught they attempt to pull all of the bad parts out and off the line but they told me a few got through.
So pm26 you are correct in that someone did not do there job and I assure you some sort of disciplinary action was taken.
The tail gate to my understanding will be thinner thickness.
There are no adjustments.
Crazy that the "few" that got through all ended up on your street. Something tells me it's more than a few.
no just saying I check around my neighborhood and found these 2 others and you are right that is why I got on this forum to see if there were any more out there. In fact I found another person with the same issue at a mall 15 miles from my house. Also had someone from Jeannette PA. hit me on this forum and said they had one.
Just wondering how many?
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
