How does the truck know....
Not sure if this has been asked before, didn't really know where to post this question either but.....
When you rotate your tires, how does your truck know?
Your dealer and all tire retailers have a tool to relearn each tire. It just takes a few minutes.
Now this is if you rotate your own tires right? I mean im sure if we take the truck in to the dealer or tire shop they would do that anyway if they are the ones rotating them.
There is a process you can do the required you to put it in learn mode and inflate/deflate each tire, should be in the manual.
Or you can pony up $75 and but a relearn tool, makes it quick and easy.
I check my tires at least once a month and I am not going to trust a sensor to always give me the correct pressure. My local dealer has rotated by tires which is included with the "free" oil changes and they did not rescan the tires so I guess you have to remind them to do that. I will go back to rotating my own tires here soon and will continue to check and add if needed every month. If the DIC says one is low then I will want to check all of them anyway.
I've had TPMS sensors for 9 years now. They've never measured off from my high quality digital handheld gauge.
This does not work on 2014+ GM vehicles, only way to do this is by using the tool. Otherwise dealer or tire shop can do it for you.
it's a Kent-Moore EL-50448 TPMS Tire Pressure Monitor Sensor Activation Tool.
That's the tool the dealers use.
I bought mine back before the price went up...
