Good morning!
I hate to be the guy that reopens an old thread on their 1st post...buuuut..
I just picked up a 2014 LTZ Z71 with 46000 miles on for what i thought was a pretty damn good deal, I was super picky about the test drive and didnt find anything about this truck i found alarming in any way, the thing is immaculate inside and out. LSS.
Got the truck home, it sat for a day before I started it, and holy crap! What the hell is that ticking sound? How the heck did I miss that on the test drive/walk around is beyond me.
Took it back to the GM dealer and they said, its normal. Well, holy god is that annoying, if i was able to hear that inside the cabin i'd be super pissed having to listen to it.
Has anyone discovered a cure for this yet, or is it truly "new technology"(the weak acceleration is a whole different subject) and I'll have to adjust and deal with it.
Thanks again!
6 hours ago, Farmboss said:
Good morning!
Thanks again!
If you’re not used to DI engine noise it may sound horrible. The injectors are noisy and seem to get even more noisy over time. Especially irritating when using a drive through service like fast food or the bank. As for the acceleration issue, it could be related to what many attribute to the gas pedal sloppiness. There is a thread on that here somewhere. Just Google GM truck gas pedal fix and it should bring you to the thread...it’s not letting me copy and paste for some reason.
Yessir, i've stumbled on to the partial fix some folks are talking about with shimming the pedal or replacing it with a different PN. Thanks for the input. I find the noise to be irritating outside the truck, thankfully I dont hear it inside, its dead quiet in the cab, the wife loves how it sails down the road. Guess its something i'll just have to get used to. Thanks again.
  • 3 months later...
  • 3 months later...
  • 4 months later...
2017, 1500 Silverado LT 5.3 liter engine
33,000 miles  quiet as a mouse until 2 weeks ago. Then LOUD tapping started on drivers side in the wheel well also under the hood.  Truck has been dealer serviced since day one.  Regardless of what anyone says here. I believe it is NOT normal.
So called Normal sounds like an easy way out for GM.  No modern motor has Tapping, Ticking, and or Knocking.
I WANT MY TRUCK FIXED !!!
Joe Fratick,    Dunnellon Florida
If it’s that loud and it’s on the driver's side it’s most likely the brake vacuum pump. There’s a recall on it...take it in and get it replaced.
Other than that, hate to break it to you...virtually every modern engine now is “loud”. The days of those Lexus commercials where you didn’t even know if the engine was running, are LONG GONE.
They now wrap these engines in foam insulation’s to try to combat the direct injection noise. All of them have to do it. Open a hood, it’s there...the noise, the insulations. In terms of noise, the silverados I’d say are about normal/average on the spectrum...there are others much worse.
I also have ticking noise I’m my 2015 1500 can hear it well from
drivers side fender... took it to dealership and they tried to tell me not to run 89-93 octane and only run 87. I tried the sea foam injector cleaner that didn’t work still ticks
  • 5 months later...
I purchased a new 2015 Chevy Silverado in 2015 and now when i start my trucking i hear this ticking noise like a lifer and its really noisy when i first crank it on the driver's side of the engine don't know what it is but very annoying. It stops after a minute or 2. Any ideas whats going on.
Welcome to the site.
Think you might have answered your own question unfortunately.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
