Power Running Boards
Looking into getting some power running boards for 15 Silverado. Seems as if AMP has the market locked down of you want these but was wondering IF there was any other power running board options? Anyone know of any or had experience with others?
  • Replies 39
Amp and Bestop are the two i know of and from past experience the Amps are better in the long run. Amp even has the Power Step XL's now designed for lifted trucks to give an additional 2-3 inches of drop.
GM is coming out with a new set for the 2016 Crew Cabs.
Not quite sure I like how they don't tuck up as high as the AMP power steps.....and if they are coming from GM, guaranteed to be $2000 or more lol
It's only for the High Country right now, And I'm sure its ECM controlled but its a 995 dollar option.
I love my amps best thing I have done to the truck. Also everyone who has got in my truck loves them.
I don't have any experience with them but Bestop has a wireless version where you don't have to splice into the truck wiring or the OBDII port:
http://www.bestop.com/products?view=product&id=140
Seemed like a great idea to me, so I looked into the Bestop steps before getting my AMP Powersteps in June 2014. Things may have changed, but the Bestop did not have a lot of good reviews, their warranty was shorter than AMP and every truck accessories dealer I called in the Austin area said they stopped carrying them because of all of the problems. Mind you, things might have changed, but you should do a lot of research before buying them or any of these products for that matter.
Do a search of Bestop...there was also something about the relationship of Bestop to AMP parting ways...
  • 3 months later...
About to install Pro Comp 2.25" kit w/ ko2 305/55r20 and was debating on installing the amps. I like the look of the XLs but not sure if they're overkill for a 2.25" kit. What are y'alls opinions? Thanks
Too much for that little lift. My standard AMP steps are just about right for 2-4". I doth think you'd need the XL until you get above 4" (fender measurement)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
