2016 All-terrian
I just noticed the headlights on the All-terrian are blacked out vs the standard '16 headlights, look great!
Also noticed the All-terrian has both upper and lower aluminum control arms vs the standard steel ones.
Anyone else notice this?
  • Replies 69
Wow, that is an actual aggressive looking tire on it as well.
Please tell me you are joking, those are still the junk Goodyear's that GM has been using since '14.
Lol no. Those are the same crap goodyear SRA's that everyone complains about. They were shit tires.
This is my 15
Thank you, I knew SOME half tons received aluminum lower control arms but didn't realize they got both upper and lower, cool stuff.
Side note, the frame coating looks amazing on those two trucks.
What's even crazier is that they are both Fort Wayne trucks which are known for having the worst frame coating.
so does this mean it uses the LED DRL as a blinker?
If its like the Silvys they will be switch back and light up white and flash amber
The projectors are different too. Perhaps the All terrain is LED and the SLT is a HID projector? Let's see some pics of them in action! Or video!
Unless they've changed, frame are waxed at supplier, not at assembly plants.
