Biggest 17" rim/tire combo
Boogie651
8 minutes ago, flyingfool said:
wouldn't a  chassis lift might be a better decision  for wheel clearance...instead of grinding the fenders
Yea more lift will be better but some people like the big tire tucked up in the fender. So if you dont want it to rub you have to trim. I never would trim but to each there own. They look awesome when you can tuck a 35 on a leveling kit imo
  • Replies 33
1 hour ago, jgraves13 said:
Gonna do this at some point too. 285/75/17 on methods with a 2.5” Coilover level in the front. Here’s a clean video for the k2 trucks for the NorCal mod. Can also do the zone trim plates that clean it up a little bit better
Yeah I’ve seen it. My truck is a 2015 so I wasn’t that scared to cut it. Just make sure to put some spray paint so it doesn’t rust out. I know rough country sells some trim in plates too but I didn’t trim that much so I didn’t need them. I want to put 35s on next so I’ll have to trim more. I’m going for Baja style.
I liked the tucked and stuffed look, but not willing to trim sheetmetal on such a new truck!
Only reason I would consider it is because with the zone/RC trim plates, it looks factory after install because the plastic trim piece and liner go back in the same spot
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
