Metallic Interior Rattle
650h1
Anyone else have a metal on metal rattle coming from the passenger side interior? It almost sounds like it's in the door, or under the passenger seat...
My passenger seat rattles when positioned up high, lowering the seat stops it. I've tried looking for the source with no luck.....go figure.
I have a metallic tapping sound coming from the rear door area when hitting bumps. Please let me know if you find out what it is. I can't figure it out.
Lets hope someone finds out. I was going to open the door and just bang on it and see if I could make it replicate the noise and see if I can get it to happen again.
I had someone sit in the back passenger side seat and I went ride and as luck would have it, I didn't hear anything.
Wonder if you tried folding the rear seat up and see if it will still do it.
I had a noise coming from my rear upper seat. I found that a hard plastic u shape isolator that came off of the ushape bracket and fell to the floor. You can see if this is the problem by grabbing the top cushion and moving it front to back. I zip tided the black plastic u shape unit back into place. What a plain to get to the zip tie. I plan on taking it in before it goes out of warranty. But for now it;s working.
I had to zip tie my right back one on want have to worry about it ever coming off again. Checked the drivers side back and it was almost off snaped it back in place and it is staying put.
The rattle I can hear is definitely metal on metal, and I've shaken everything in that area with no luck getting it while I've been stopped. It almost sounds like its coming from under the seat or the glovebox. I've checked both areas, and nothing seems to be loose... Irritating.
I've heard the same thing before but I haven't really investigated it.
Did some more searching for it tonight, it sounds like it's under or behind the radio in the dash... If I sit in the drivers seat, I can hear it on the passenger side, and if I sit on the passenger side, I can hear it in the middle. Irritating that I can't find the frigging thing...
I tried that and it still rattled.
Still can't find it... At this point it's really pissing me off.
Take it in... i think I've read about that issue it's the passenger seat. I wanna say it's the bracket
Can you find a link? You know what the dealer is going to do..
