Weathertech- Not having a good experience.
fpdsniper
I have the issue with the weathertechs too. The Velcro stickers that are used to hold the clips also don't hold for too long as well. I've just been lazy about calling WT to see what they will do. If nothing, then I'm going to look at the Huskies again. I do love my rear mat though. I like the full coverage that I get with it and it doesn't have any fitment issues.
Yep, I have this issue also. Thinking of calling and ask for replacement Velcro.
  • Replies 68
I got WeatherTech mudflaps for my 2015 Sierra just the other day. The rear flaps with their flip over locks were a pain in the ass to install. It took me about 30 minutes/side to get the locks to move into place. Still not sure they are where they belong although they seem to be in place so far.
The fronts took about 5 minutes each. Plus I'm confident they aren't going anywhere.
When I'm ready for floor mats, I can guarantee I won't consider WeatherTech.
See I did buy the weathertech splash guards even though I have the Husky mats. Great design and were real easy. Id say 5 minutes a corner on christmas morning after everything had calmed down.
I had the Weathertechs in my ram & they fit perfectly, but in my wife Camry, not so much. This time I bought the Husky X-act fit for my Silverado & they are perfect. They are moulded rubber instead of moulded hard vinyl like the Weathertechs.
I've had Weathertech in every vehicle for the past 6 years. I called to order them for my 16 All Terrain and the sales rep talked me into Husky X-Act fit liners. Well, they came in today and I think they are total crap and immediately called AutoAnything and got a return authorization and sent them back.
They didn't cover quiet as much as the weathertech's up front and the full rear piece looked cheap as hell. I didn't like how the husky rear only had ridges under where the passenger feet would be. The rest of it is just slick cheap rubber. I keep my rear seats up most of the time so I can keep gear from work and occasionally my English Mastiff. He would be sliding all over the place back there.
I love how the weathertech rear mat has some texture to it. Yeah the front edges slightly deform, but I think I can deal with that better than the slick rubber in the back. But its all personal opinion, i know. We can't all like the same things
Not impressed with the WTs at all! They don't lay flat at the rear and catch the seat when adjusting forward. Passenger mat also falls away from kick panel as others have noted. Just terrible.
Mine are doing the exact same thing not impressed a lot of money for mats that I'm tripping over
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
