Hey all! Disappointed that my first post is going to be a negative one but i'm curious to see if anyone else is having this issue.
2016 Silverado All-Star edition. Since I purchased the truck on 12/31, I've had this issue six times. You start the truck and the 8" Mylink screen is blank. No power - cant turn it on, no radio, etc. It's happened under different scenarios, after remote start, key start, etc.
it's back at the dealer for the second time. They called me and said there's software updates to fix this issue. The salesman indicated that this is a big issue on 2016 Chevy's - cars and trucks.
Anyone else have this issue on their 2016? I've read about 14's and 15's, you'd think a 2016 would already have the updates.
I love the truck otherwise!
--Steve
This is off topic a bit but I wanted to see if anyone reading these radio related posts might be familiar with a radio problem I am having. I have 2015 GMC Sierra and since installing new HID headlights I can't assign stations to all my presets. I can only use certain radio presets numbers and on top of that I can't assign any XM stations as presets.
--Steve
14's and 15's have different radios, so software fixes for them do not apply to the 16's and vice versa. Also fixes are only applied as problems are reported. When it comes to software and hardware versions, don't assume you have the latest unless dealer confirms it.
so far mine has been good. 10/15 build date purchased saturday after thanksgiving.. i have had the pandora bleed through during a phone call to a doctor, that was interesting i thought it was on his end lol.. then i realized it was billy joel which i was listening to before!
So far haven't had issues since the software updates.
That's good to hear. I've had issues with CarPlay, but I don't believe it's directly related to what you were experiencing. Do you know what they updated on your truck? If they simply updated the MyLink, what software version did they update it to? Should be in your Settings.
What issues have you had with CarPlay? I had one issue where it disconnected and reconnected but haven't had it happen again. I believe they just updated the MyLink software. I'll get the software version tomorrow.
Got the truck back from the dealer on Monday. At first they told me they replaced a module but apparently that wasn't the case. The paperwork says an issue in the x275 connector under the dash near the hood release. Pin 11 was misaligned causing the issue. So far, its working fine - but we'll see.
Took about a week last time for it to act up again.
They use the term screen won't wake up. My 16 is good but my 14 had the problem and the update fixed the screen and created numerous issues that they couldn't fix.
it happened on my 14, more times than I can remember. 3 days after driving it home. Each time it blacked out, I still had a working radio.. As in even though it was black, I could guess where buttons were and change stations. Only thing that didn't work was the volume nob. The steering wheel controls worked fine.
Every time I took it in, they said it's called 'logic lock' and their fix was to see if there was an update and or disconnect the battery. I don't like the morons there and if I kept band-aid-ing a broken item at my job, I'd get fired.
So when it happened again, I took it there while it was black. Left it running so they could see it not working. I wasn't taking another update fix anymore. I was adamant about what they've done prior wasn't working. They had my truck for a week replaced the hmi screen and a cable. Was good for a month and it happened again.
Took it back, they had it for another week and replaced other stuff and calibrated the door switch? Whatever they did seemed to do the trick. Haven't had the problem in months. Knock on wood.
I'll dig up my paper work to see what they replaced if it helps.
    Clark_Elite
    Clark_Elite
  • Who's Online   4 Members, 0 Anonymous, 458 Guests (See full list)
