2015 Yukon Denali Buffetting Issue
Chris Fano
Hello, I just recently test drove a 2015 Yukon Denali XL.
When I came back from the test drive my ears hurt and I had a headache.
During the test drive, there was this constant "thumping" kind of sound like pressure was building up in my head.
Upon researching some forums and complaints, I come to find out that the truck has issues such as this.
Can a GM technician please tell me if this has been corrected on the 2016? Is there a fix for the 2015?
I would like to know before I purchase an almost $80k vehicle.
Thank you in advance.
I've found that anything built after the early '00's does this if I have a window open a crack. It's a loud, deep, bassy, buffeting sound that will drive you nuts. None of my older cars do it, but my Silverado does. My mom has a little econobox Honda that does the same thing (in addition to feeling every single imperfection in the road ... and in MA, there's LOTS of that ...).
I wouldn't count on anything like that being fixed. I'd bet money on it.
My 2010 Sierra extended cab creates a sound in the interior like there is a helecopter in the cab of the truck that starts at 40mph when the rear windows are open. If I crack a front window open about an inch the chop-chop noise stops. My 2000 Grand Prix also did this. Real annoying when all I want to do is have a window open when on the highway and still be able to carry on a conversation with a passenger sitting next to me. Given it has been at least 15 years since I first noticed it, I would agree with Jsdirt's comment about it being near normal now.
I would see if there was a 2016 model available somewhere that I could drive. Does not need to be the same trim level, or even the same configuration, just needs to be same model. Take it out and see if you can make the noise stop by trying various window positions. You don't say if the salesman went with you on the test ride, if he did not, take another test ride and this time take the sales man. If the noise happens again, point it out to the salesman and see what he has to say. I would not mention this noise to the salesman prior to the test drive, make it appear like you just noticed it. That would be the best way to get a honest reaction from the salesman.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
