Normal operating temp
Hi, new guy here. I've had my 2013 for a few weeks now and noticed the temp gauge stays around 210 degrees. My old truck, a 98 K1500 would normally stay around 190-195. Is 210 the normal range for the 6.0?
thanks
The gauge is dampened, my 2012 is the same way but real temperature is low to mid 190s via an Edge Insight.
That's about normal, pretty much where mine runs especially when outside air temp is above 60 deg. I would just keep an eye on it, check coolant levels, follow recommended service intervals.
210 is normal pretty much year around in this area for me anyway.
Yup
210 and mine is very steady at the 210 year round, plowing / towing / empty bed
Each psi of your Coolant system increases the temp at which water boils.
Sent from my SM-N920V using Tapatalk
You have to go with an aftermarket reader. I know the diesel it'll read 210 on stock gauge and will vary from 185 to 210 before it starts to rise. Typically stays 185 unless the truck is pulling.
