Factory high performance headlights
Hey guys. I priced out a new '16 Sierra today and wanted to make sure I was getting good headlights. I noted the Denali has some special lights that are optional on an SLT (which I am going to order). The question I have, is it worth the added cost? The option code is PDP-Headlamps, High Performance LED Headlamps. It will cost me $500 CAD for this and already I'm looking at a truck with an as built price of $65,375. Thanks for any input.
The optional LED headlights are the ones that automatically go into high beam mode I believe.
You're spending $65.5 large and you're worried about $500?
I would bet that one of the options packages that you checked off is already including the high performance headlamps.
You're right, I thought the same 'what's another $500', but if there is little difference in brightness or how much more it illuminates, I'm not interested. I'm not adding the block heater, not due to the cost, but simply because I don't need it. If it is the auto dim or high beam as Tjay74 remarked, I'm not interested. According to the salesman, it's not standard on the All Terrain or AT Premium package.
The LED headlights are worth every penny. If you are unsure, ask your dealer to let you drive both options at night and make the choice.
Thanks guys for all your help. After further research, I'll be adding them to the truck. Thanks B.A.I, I am glad someone chimed in with a real world experience as well. BTW, the Intellibeam headlight (code TQ5) is a separate option.
I think anything higher the a a/T is getting them anyway as part of a package, sle get them in a all terrain, otherwise I believe slt and up, I drove a 16 with them, there awesome, I also thought the intelibeam was part of this but it is another option
At this time, the PDP option is mandatory on SLT.
Intellibeam (TQ5 NEW! Headlight, IntelliBeam, automatic high beam on/off - Included and only available with (Y86) Driver Alert Package) is a separate option, and is available on sle and slt.
(order guide says PDP mandatory on SLT 'at start of production', but the requirement is still in effect)
FWIW, the LEDs can be added to an sle by adding the all terrain option.
"PDP NEW! Headlamps, high-performance LED headlamps with GMC signature LED lighting
On SLE - Required and only available with (GAT) All Terrain Package.
On SLT - Required on SLT at this time. Included with (PDT) SLT Crew Cab Premium Plus Package."
LED headlights are standard on 1500 Denali. (but Intellibeam is an option)
That's odd, because when my salesman went to make the order for the truck, it came up as a $500 option. The truck I will be ordering is an SLT with the All Terrain package.
I wish I had these headlights in my '15. I had the the "fix" done to my headlights, which helped. However, they still suck big time, IMHO. My LED lightbar sure does the trick though, when there is no other traffic around.
I am so confused about this. My new truck is at the dealer but I haven't picked it up yet.
2016 GMC Sierra SLE with SLE preferred and convenience packages
Window sticker says "HID headlamps with LED signature lighting"
This is an actual (cropped) picture of my truck at the dealer
Are these the "good" headlights? There is a GMC bar over an orange light there but my headlights seem round where the other picture here seems oval
Your headlights are HID and the "c" shaped band is the LED part (daytime running lights/parking lights)
The optional headlights are full LED, both the headlamp itself and the drls. The full LEDs also do not have the amber light (turn signal) as this is incorporated into the LED band.
Sent from my SM-N910V using Tapatalk
Be sure to check both sides of window sticker.
They often list the 'standard' equipment for the trim level on the LH side, and the 'as built' options (with pricing) on the RH side.
decee, if the truck is an SLE, the LED's are "required and only available" if it has All Terrain.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
