Please help....I have a 2010 silverado and all my lights work except tail running lights...checked fuses all good..only getting 3vdc when I check voltage...all other voltages are good 12vdc....when I use the key fob all lights blink as they should...even the tail lights....please help I cannot afford to take this somewhere and I am stumped...
