Towing a Travel Trailer with Regular Mirrors?
Tek74
Yes, I completely understand that larger tow mirrors stick out farther to allow the driver to better see the travel trailer that you are towing.
I'm just curious if anyone has ever tried towing a travel trailer with regular mirrors? Is it just "harder" to see the trailer, or is it "impossible" to see the trailer?
I'm just asking because I have regular mirrors and was contemplating renting a 20' trailer in the near future for a camping trip to see if I like using one enough to buy one.
I have towed a 30ft travel trailer with the standard mirrors on my 2001 Sierra 1500. I could see the trailer just fine, I could not see down the side of it. I bought a set of trailer mirrors that slip over the truck mirror. They just add a second mirror that is about 6 inch further out, you still have full view of the factory mirror and can adjust it separately. Hell, I liked the tow mirrors so much that I left them on the truck. I sold that TT about 11 years ago and still have the mirrors on the truck.
My advice is to buy a set of the mirrors. Here is a link of some that fits our 2015's:
http://www.ebay.com/itm/2014-2015-2016-SILVERADO-SIERRA-CLIP-SNAP-ON-TOWING-SIDE-MIRROR-EXTENSION-/171559935117?hash=item27f1c4dc8d:g:ZCMAAOSwj0NUjQPY&vxp=mtr
I tow a deck boat and it's wider than my truck so I like the fact my tow mirros see around the boat and behind the boat. Keeps an eye on my wheels also so I stay in lane as well as turning making sure I don't hit any curbs. It's about safety. Some states require tow mirrors. Depending on how wide of a trailer you get determines how much you can see around and behind
sent from Florida beech
I did one 30 min tow with our 27'TT. Could not see anything but the trailer. Could not tell if I could change lanes, if I was getting pulled over nothing. It was horrible esp since my last truck had them. The dealer wanted no part of putting them on for me before the purchase. I bought aftermarket for about $200 and called it good. If you are doing a one time tow I would not spend the $ a set to bolt on. Here in MI you can also be ticketed for improper equipment for not having mirrors that you can see behind.
I would urge you to make your trailering experience as pleasurable and stress free as possible. Check with your trailer rental location to see if they offer temporary trailer mirrors for rent.
Many (most?) other parts of the US as well.
I started out with the regular mirror's towing my 33' TT, I towed it about 11 miles to the RV dealer and bought a set of mirror extensions. I did not like not being able to see behind me at all. My new truck I ordered actual tow mirrors as soon as I got home from the dealer
I didn't know that they made extenders that attach to the regular mirrors. That's definitely the route I would want to go, as I don't like the look of full size tow mirrors.
I used the extenders that they sell at e-trailer for one camping season. They worked well, I just wanted a bigger view and power adjustment so I had my dealer install the tow mirror upgrade my truck this year.
If you want the extenders, PM me. They are just sitting in my garage. I'm sure we can work something out.
I've towed with regular mirrors and strap-ons. If you are renting a unit occasionally, you'd be OK.
If you buy one, hit up ebay or someplace and get the jogger-smackers. I added them to my Sierra and LOVE the visibility - towing or solo.
They are everything and more when towing. Much nicer not having to store towing mirrors, too.
  • 1 month later...
At least get the snap on ones but, If I was going to trailer much, I'd want the trailer mirrors on my truck.. They do look kinda goofy on a 1500 for some reason though.
    • They are talking about adding more tax to our fuel across Canada by the labour day time frame, its the carbon idiot tax increase on top of the pile of fuel taxes we already pay thanks to the WEF dictatorship running the country. 10 cents per liter on gas and 4 cents a liter on diesel I believe is what was said. That is a huge amount of a tax increase as its another 38 cents equivalent to a US gallon of gas. The reason our fuel is higher than the states already is because of of the high taxes they have imposed on fuel.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
