Fun button
Stability control turns back on at 35mph nomater what. Plus it's annoying to have to hold down the button for 5-10 seconds. I've had stability control turn back on while I was mid drift and almost put me off the road, not a fun experience. Now all I have to do is turn my new switch to off and everything stays off.
Lol ya almost did this myself,
I hit 35 bye then end of my street, especially spinning these awesome Goodyear's thru the snow, then start all over again, yes annoying as hell, does ur dash light up when off? I'd love more info on your wiring route, any breakers or anything in line? And where did u mount switch
Thanks
  • Replies 41
I don't think you have seen my video a while back... I turn everything off tc. And stb. And I can only spin my tires for almost 2 seconds. No where near the 35mph...
I think your truck only spins for 2 seconds because it rips through first gear so quick and shifts. The problem with the 8 speed it that it cuts power on shifts, so it wont keep ripping like a camaro or vette 8 speed. I do know if you put it in manual mode 1st the truck will rip a decent burnout banging off the limiter. But once it shifts into 2nd, it's game over.
Hell i will go buy a switch this weekend and do this? so your talking about the ABS sensor to the front hub? is it just stranded copper wire you spliced into with a switch?
im my CTS the steering position sensor was acting up, i bought a new 1 but decided to just unplug the faulty 1 and leave it be.
every start up i got a notification "stability system disabled" clicked ok and was fine.
with the steering position sensors when they start to go bad it actually affects braking. i felt like the brake pedal would actually buzz and push against me for about a second sometimes. kinda like the buzz you get from the abs feedback.
Correct, the plug is right there on the frame just inboard of the drivers front tire. Make sure you seal everything back up tight, don't want water making it in where you splice.
I was told a tune from bb would cure this headache
I was curious about this if stabilicrap and TC could be tuned out........ Anybody know for sure?
sweet that is easy i will have to get around to it one of these weekends. Dam i wish i had it for this winter. just when you felt the rear end locking up in the snow t/c + stablitrack would shut you down real quick like a big F UUU. seriously it screwed up my momentum so bad sometimes i was forced to put it in 4x4. my old 2500hd was like a freaking half track i could go anywhere in 2wd.
  • 6 months later...
Old thread but this is the main issue I have. It's a nightmare in the snow, I was nearly rear ended by a log truck because of this Stabilitrack system.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
