Had a very annoying dash rattle near the hood latch. Removed the 2 Lower torx screws and pulled off the panel under the steering wheel. There are 4 bolts concealed behind this panel. 3 of these bolts were ready to fall out. Tightened everything down and no more rattles.
  • Like 5
I found the same thing with my 14. I bought it used and blamed it on the previous owner dorking around in there. I found small black wires spliced in to the headlight switch also. Must have had LEDs or mounted somewhere.
The one rattle I cannot kill is the door panels. The trim on both doors buzzes on just about any rough surface.
Edited by Eddie 70
Have the same thing on my 15, I asked the dealer to take a look at it last time it was in and they actually replaced the hood latch mechanism - didn't fix anything.
I'll have to pull that panel off today and take a look at it.
Sent from my SM-G920V using Tapatalk
I had a rattle underneath the dash that I thought was a loose hood release cable causing the latch to vibrate but as it turns out it was the entire assembly itself. There are "heat stakes" and one was significantly shorter than the others from the factory. Dealer swapped it out and it hasn't made a peep since. It sure was a chore to figure out the cause, however.
Maybe the dealer has delt with that issue before and assumed it was that?
Just picked mine up from the dealer again, it was the same bolt mentioned by the OP and a loose clip behind the headlight switch.
I have what I can only describe as a kind of... I don't know really... a buzzing esque... pressure bleeding... wind noise? I have no idea coming from under my dash for the last few thousand miles (just hit 7k yesterday). I have not been able to figure out what the heck it is. I wonder if it is related to the screw you mention...
I have the same issue, If I touch the panel it goes away. Going to see if tightening it helps.
Edit: Just hit about 8K when it started happening.
Edited by ic3man5
That seems to be an easy way to tell if it's the screw causing the noise, mine was the same way - touching the panel made the noise go away.
I was around 16,500 with mine when I first noticed it
I have the buzzing noise in my truck, coming from the lower dash area too. I thought I fixed it a few weeks back by removing the one trim piece where the hood release is, and I tightened up those four bolts in the pics above. But lo and behold it started buzzing today. So annoying, it's only at certain speeds.
Drives me nuts though. Goes away when I push on the panel just like you tho. Gotta figure this one out.
I am thinking about drilling a hole thru the panel, and then putting a round head bolt thought with a nut on the back side (under the dash) and tightening it down to hold whatever is inside the panel from buzzing.
Edited by fondupot
my particular dash rattle was actually coming from the top panel where the speakers and the light sensor is. i just popped the panel off and taped the gold like connectors with electrical tape for "cushion" and my rattle is gone!
That's what mine is doing same thing. I need to do this. Driving me nuts,mine only does it at certain times.
Mine had the same issue under the steering wheel when I bought the Truck, I love how you can see the blue mark where someone actually checked off after it was tightened. They need to adjust their screw gun at the factor.
Yup two bolts were loose... requires a 7mm socket. Bottom left one was barely in
Thanks for the pic, I will see if this helps the issue I am having. Mine does not really sound like a rattle. More like a pressure/air leak or something. Who knows though it very well could be this and just sounds odd.
