2015 5.3 LTZ
I have a tread but the search engine here does not seem to find it. I have what I quickly tuned tuned in as an exhaust vibration. GM tried to fix it early on but it came back.
My complaint was a noise and vibration at 30-40mph under light load. What I did not realize is how much vibration I was feeling at all other speeds and loads.
GM recently replaced my exhaust. Holly crap. I did not realize how much I would recognize the improvements it would make all ALL other speeds. I cannot hear or feel the difference in V4 any more. I don't feel the throttle pedal vibrate at all speeds. When I accelerate hard I don't feel like an injector is bad past 3k RPM. Seriously the engine shook.
Honestly I keep looking at my dash to see if I am in V4 or V8. The truck is smooth like a new truck is supposed to be. The drone is gone, small vibrations that I would not have tried to complain about are gone.
I have no idea what is different about the new exhaust. I posted this because in the Yukon forum they say a new exhaust is coming to fix the vibration problems. I used to hate this truck, it is really nice to drive now. I keep my radio off in disbelief of the improvement.
Could explain why so many trucks vibrate at the same speed range. Some of the other vibrations at other speed ranges could be slight variations in the exhaust.
Will be interesting to see how this might progress.
Edited by polarys425
Would be good to see a side by side comparison of the old & "new" exhaust, or to know what the difference is.
2015 5.3 LTZ
Do you know if they went exhaust manifold back? Catalytic converter back? Please provide some more details. Gas pedal , anything in steering wheel?
I can say i had the exhaust pressure in my truck adjusted once, and it helped for a while, but got worse again. I've heard rumors of high flow exhaust systems helping, but I haven't tried it so I cant say for sure. regardless, I sent a final repair notice to GM this past Monday.
They first adjusted my exhaust and the vibration went away for 300 miles. This time they replaced whatever amount is needed to replace the flap valve in the rear. I have a little more than 300 miles now with fingers crossed it stays fixed.
On a side note, do any of you hear kind of a "tinny" sound on acceleration from the exhaust? On my company's '15 6.2L Yukon XL Denali it has the sound under heavy acceleration and slight vibration of some sort.
In V4 mode the sound was very tinny, like ping ping ping. It is gone now. I hope it is gone for good. It is crazy how different the truck is now.
The truck is running like a sewing machine. I am nervous to jinx my luck. I have my radio off most of the time waiting to hear the crap some back. But so far so good.
  • 4 years later...
Same stuff happened to my 2018 Silverado there was a vibration in v4 mode they replaced the dampeners. There’s still a vibration but it’s very slight not like before but I’m still not satisfied.
  • Confused 1
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
