Group Buy: Morimoto XB LED Fog Light Housings
How do these install on a 2014 Sierra (with factory fogs)? Just wondering how long it would take do do the installation and how difficult it is?
I am going to make an install video once I get mine. But I have been told the install is pretty easy and can be done in about 15 mins.
  • Replies 188
I am going to make an install video once I get mine. But I have been told the install is pretty easy and can be done in about 15S
Sounds great! Thank you!
Anyone have a picture of the Sierra fogs against their chrome bumper from afar?
I am a sucker for looking right and to be honest, despite the killer deal here, I really don't know if it'll look right on my truck. Silly I know...
I've done my swap. It really wasn't that bad.
Did you have to pull the bumper?
Nope! I'm on the 3rd group buy, but you just have to crawl underneath the front and locate the screws. Really that easy!
Hey everyone I just ordered mine yesterday. I'm on the 3rd order also. Just three more left!!! Hurry and order up this is a great deal!!!!
I looked under my truck and I even removed a couple of 15mm bolts but then determined I didn't have the time to finish so I backed out... Looks like it'll take me a few hours really..
I'm doing it now on my Silverado. Here is my quick and dirty how to. I didn't go into to much detail because once you get it apart it becomes clear what you need to do. Feel free to ask any questions if I was too vauge.
You need to pull the two lower fender liner for screws to be able to flex the fender liner, then pull the bumper support bracket out. Separate the fog light housing from the bracket.
Next separate the shroud from the housing by threading the bolts and prying the plastic tabs back
Unthread all three adjustment screws and the stock fog falls out.
Next look at the back of the LED for light and you will see two barbs and one hole. Take the two adjustment screws out of the plastic housing that correspond to the barbs on the LED fog and pull the adjustment screw out of the white/yelllow plastic bushing. Push those bushings onto the plastic barbs of the LED fog. Now take and pull out the plastic threaded insert of the factory fog and put it in the third hole of the LED fog. Below you can see one barb has the plastic bushing on it and the hole has the plastic threaded insert, both from the factory fogs.
Now thread the renaming intact adjuster into the plastic threaded insert like below
Now you should be able to push the three plastic bushings, which are attached to the LED fog light back into the housing. Make sure the bushigns are pused al the way in so the plastic cleats engage. Now reassemble and then aim the fog after.
No I did not pull the bumper. There are about 6 or 7 15mm bolts on the steel fog light brackets that need to be removed to remove the bracket with the fog lights still attached.
Went ahead and ordered since I think I will be number 10 for the third group. We'll see.
I know they will perform just fine. I'll see about getting them chromed or something.
two more orders needed for the 3rd group buy!
Just 1 more order need for the 3rd group buy!!! Lets go guys!!
