Group Buy: Morimoto XB LED Fog Light Housings
I read through this thread and didn't see much mention of how you all found the fog lights to perform.
How was the lighting output improvement over stock fog bulbs and housings? Does the XB fog project further out and wider?
Anyone able to comment how the XB fogs compare to say Putco or Vanquish Auto(they appear to have 80W LED fogs).
Any input you can share would be appreciated. Thanks
imo these fogs are and work awesome
Nice cut off and lights up both ditches.
Oh I had the putco Luminix before I seen this thread and they are crap [emoji90]
Grizzly
  • 3 weeks later...
  • Replies 188
Oh I had the putco Luminix before I seen this thread and they are crap emoji90.png
Grizzly
Thanks very much for the response and feedback. Direct plug in as well in terms of wiring?
Grizzly is spot on.  Even a complete slacker like myself was able to get these put on in 50 minutes on my 2015 GMC.  This includes watching a 15 minute YouTube video.  Next install on a buddy's 2015 Denali Duramax took about 25-30 minutes. Huge improvement over stock foglights and won't blind oncoming traffic with glare.
  • 1 month later...
Any The Retrofit Source group buys for HID headlights right now???
  • 3 months later...
I have some 5500K hid bulbs from TRs is anyone needs them. Pm me. Same bulbs you would use in the retrofit kit. Had them for a few months before i updated projectors.
  • 2 months later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
