Option not available
I want to order a 3500HD SRW Denali with a centre jump seat, but it's not an option. So I thought I'd order the truck anyways and install the jumpseat, is it possible? How come big families can't have nice vehicles to.
People want the full length console. I'm not sure converting it would be as simple as you think. I'm pretty sure the subwoofer lives in the console as would some other electronics most likely. Then you have to deal with finding a seat to match and that may not be feasible depending on what color interior you have. And that all assumes the bucket seats are the same with and without the console.
Agreed with this^ there are a lot of electronic and the sub I personally would just order an LTZ with the bench, save yourself a lot of time and hassle. Or tell a desperate dealer that they need to put a bench in your nali' and that's the only way you will buy it
Pretty sure you can order a fully loaded SLT with the jump seat. I had one as I have a big family too and it's a necessity for me.
Trade one of the kids in for it? You get to enjoy the console amenities, might get lower payments if the kid is cute or smart, less money spent to feed them.......it all seems pretty win win.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
