8 minutes ago, 20165.3Eco said:
I think it's pretty silly we are all chasing what is clearly a design/quality issue.
When the truck is quiet it's such a pleasant vehicle to be inside. When it ticks it is like someone is tapping an ice pick into my brain.
What’s pretty silly is that General Motors still has a customer base after selling so many of these ticking, clunking, rough riding bastards. I don’t care if this is fixed when I start my truck in the morning and I never have another problem. GM has blatantly ignored issues with bandaid fixes and I have no desire to give them another penny.
Hahaha.. Don't worry, we'll find it..
All i can say is I'm glad its not a complete engineering failure. I'd be really pissed if it was some kind of safety concern, or a mechanical disaster..
Our 2011 equinox! I'm so glad gm owned up to all the problems.
Basically had to rebuild the whole motor - after warranty.
Ha, I just picked up a 95% rust free 88 Dodge D250. It has AC and Cruise control and is pretty darn quiet inside/rides about as good as this truck. For about 3000-4000 bucks I can toss in a spare overdrive trans I have and add EFI with a freshened up 360. Should make 350-400 ft/lbs and tow pretty well.
5000 dollar truck that doesn't tick seems like a pretty good option right now.
Seems like we're getting close. I wasn't buying into the tick being related to temperature, but as summer temps have gone and it has been generally cooler, the tick has been less frequent. I swear it was constant all summer
So what do we know. Its not vaccum pump or catalytic converters. Must either be in trans, fuel systems, mechanical in top end, pulley or water pump. Still see pretty far away. Be easier to just replace truck lol
Just got this from a buddy at my local dealer. Looks like Chevy is aware and they are working on a fix. 755e37f30625975dbc3861b38619a283.jpg
This coincides with the tempirary steering wheel turn fix someone posted the other day. I sent this to my service manager on my truck to get his thoughts.
Thank you
Sent from my SM-G950U using Tapatalk
Ya i googled it and found this :
Bulletin Number: PIP5570
This Preliminary information communicates to the dealer a conditionwhere a tick noise may be present inside a vehicle while driving. This may be the result of a deformed or improperly seated steering shaft seal allowing engine compartment
Thank you
Keep us posted please!!!!!
On 9/19/2018 at 7:58 PM, Jonty711 said:
And this was the noise beforehand. It's not as bad now but still there.
YES! This is the noise!!
Sweet, thanks for posting this. I highly doubt it will be covered under power train warranty if this is the case but I am still going to try and get my truck in to document it before my PT warranty expires in a week.
This weekend I rotated my tires, while I was at it I pulled the inner fender out of the truck and tried to see if I could get a better look at anything on that side. Everything looked fine but I tugged around pretty good on the steering boot and my noise seems to be much quieter all weekend. Still there and acts the same with bumps but much quieter.
Side note, my truck just ate another bushing for the soft lower tailgate. The dealer put in a new one less than 8 months ago. I don't really load anything heavy on the tailgate. Mostly carry tools and ski gear on the weekends.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
