trailer weight
A big thing to keep in mind with an RV is water weight. If you are camping in places without water supply or dumping facilities, you likely will be towing in with freshwater full and towing home with black/gray full. Water is roughly 8.25 lbs per gallon and 30-45 gallons FW is typical in that size TT. Also look at location of tanks and storage for heavy items relative to axles...the location will impact tongue weight.
Size - Just had that discussion with a buddy who rv's a lot. Not all parks can handle the bigger rigs - thats good advice.
Tough enough around here to find availability when you want it, let alone scratch off a few because your rig is too long.
Nice knowing others can do a 30'er with a 1500. I was getting upsold everywhere I went, and its so easy to get carried away. Just another $50/month ....
Exactly. The notorious line "oh your truck can tow that no problem...." from salesman. That has gotten many folks in trouble over the years.
What happens then is they quickly find out they bought too much trailer for their truck and wind up shopping for a 3/4 ton truck in a year after buying that big trailer.
Not everyone though. Like i said folks have different levels of what their comfortable with. There are some who have no issue towing a 30+ footer with a 1/2 ton truck,which is fine as long as they can do so and stay within the weight limits. I just personally prefer to have more margin than that. But that's just me.
Towing any trailer of any length is a seriiys thing and requires extra concentration. The combined weight of my truck and trailer is probably north of 11,000 lbs. That's a lot of weight to get slowed down in an emergency, even if properly set up with good brakes.
Also of note, most trailer tires are speed rated to 65mph max, so I usually run around 60 and just take my time. Overheating and/or hitting curbs (weakening the sidewall )are two big causes of trailer tire failure. In addition to improper inflation. I always run the max sidewall pressure, cold.
You are so correct. I error on the side of caution for driving and medical advice ( I am a nurse). 15Silver also has to account for his location. He is in British Columbia. They have real mountains in that area. Mountain passes in the West Coast of North America are much higher than most if not all of mountains East of the Mississippi.
I have your same set up, (engine, gear ratio, etc) and tow a 33' travel trailer with no problem. Dry weight is 7300lbs so with water and beer, I'm thinking it's close to 8000. Truck does well and I'm impress with the results.
if you don't mind can I ask you some questions?
when you pull your trailer do you use the tow/haul switch?
what kind of gas mileage are you getting?
have you done any performance mods exhaust, tune ect?
i've only had this truck for a year still trying to get used to it from the 03 Avalanche i had
thanks for your time
Wait..... Passenger weight? You're allowed to tow the trailer with people in it?
I use the "tow haul" mode when towing, yes. Most of my towing is around Pa, Del, NC, Va, etc. too many hills for it to trying to switch in and out of OD or hold short shifts. When on the open road, with no hills, I'll take off the "tow/haul" mode. I'm not really sure about the fuel mileage, to be honest, never really checked. What I do like is the fact that on the info center I can select "Trans Temp" and monitor the temp of trans fluids. When she's really pulling, it's just over 200 degrees.
As far as any modifications, none. I have just went from 18" wheels to 20's but haven't towed with it like that yet. I'm thinking cold air intake and a programmer next.
Hope that helped.....
I tow with tow/haul on. It makes a huge difference. Helps with grade braking also. Since i don't exceed 55-60 mph when i tow except for a short time on occasion, i also run it in M5 so all 8 holes always stay lit. I don't like it going into V4 mode with all the weight on. But that's just my preference. Towing I've gotten 12-13 mph average. Pretty darn good in my opinion. No modifications
I've read that it is legal to ride in 5th wheel trailer if equipped with communication with driver :-)
And, if RV is horse trailer with living quarters you would have passengers of the horse variety.
A few comments.
Don't even talk about dry weights on a trailer.That is before propane tanks, batteries and a bunch of other stuff. No trailer on a lot is close to it's dry weight. If you want to discuss weights, look at dry plus carrying capacity. The poster who thinks a dry weight of 7,3,00 is close to 8,000 loaded is out to lunch.
Ditto for tongue weights. Manufacturer's ratings are a joke. My trailer brochure shows a tongue weight of 530 lbs. I'm close to double that when loaded up, with about a 1/2 tank of water.
I've got the NHT. Rated for 10,800 lbs and 2,015 lbs payload. Trailer is 34"4' from hitch to bumper, but is 8,200 GVW. That leaves me under 80% of tow rating. I have not been able to weigh the trailer loaded to see how I am at payload, but I will in the next week or so.
Make sure you get a decent WDH. Not a fan of what the RV dealer sells and too often they sell an undersized unit. Seems they get a deal on the ones with 800 lb bars. Step it up to a WDH with built in sway control. I've got a Equal-i-zer 4 point and it is way better than what most use, both to control sway and just as a WDH.
  • 3 weeks later...
Well finally picked a trailer, and have a bit of experience now. 3800 pounds dry, single axle, and haven't got water in it yet, but 2 propane and a battery.
- MPG is average of 13.7 & varies
- don't seem to need tow/haul mode bad idea? better economy with it off
- came with a 10,000 lb weight distribution hitch
hitch lifted rear of truck back to level
- you know its there, but pulls smooth
- acceleration is surprisingly decent, uphill too
- braking is good, no fading (trailer has e brakes)
GM integrated controller has a time delay before trailer kicks in.
tend to feel a push when braking, then feel the trailer bite. normal? dont like it
Feels like it could pull a heavier trailer for sure, but the engine is definitely working harder than without. Another couple thou on top and I think the 5.3 with 3.42 would work hard enough I'd be concerned. I'm almost concerned with the increase I feel now. If I had a long flat highway stretch, then I feel confident one could say you wouldn't know it was there - however the roads around here are hilly.
Towing within 4 hour range I'd say a non-event. All day road trip for a couple weeks at this load I feel is aok for this truck. Pulling a boat to a local lake on weekends I think you could go much heavier - even up to the 9400 lb rating. For a work truck with constant towing I don't think this is the right vehicle. Of course that would depend what you're pulling .. just the truck does feel the difference, and it is working for sure. Day in/out work like this I'm sure would take a toll.
Summer boating, vacation rv trailer towing - its a good size for a 4-5000 load. I wouldn't want to do much more personally, but thats just my impression, based on what I've got now.
I have a 35' TT. GVWR is around 9500. I don't load it that heavy I'm usually around 8500-8800 loaded with the combination being around 13500 with everything. 15 Denali 6.2. my max payload is 1650 and max tow is 9100. GVWR combination max is 15000. GM recommends anything over 7000 to have a weight distribution hitch. Also have roadmaster assist springs installed. Yes I'm comfortable pulling it. And truck handles it fine and doesn't get hot. Also stops it well. The numbers GM puts on these vehicles they are very confident it will not damage the vehicle. So don't ever think your truck can't handle it. If you aren't comfortable towing heavy that's fine. My truck would pull my dad's 42' 5th wheel. I'm never going to try it but I know it would. But like everyone else said tow what your comfortable with. Plenty of guys out there that exceed the ratings on there truck by 3-5000 pounds and haven't had any problems. If they ever get into an accident with it I believe it's a pretty big deal with the law though. And just plain unsafe.
news article here recently guy had a trailer accident and got jail.
http://theprovince.com/news/crime/man-gets-22-months-jail-for-boat-trailer-crash-that-killed-ucluelet-woman
Reading that article, there were many more issues going on than towing overweight. While being overweight was mentioned in article, the lack of proper maintenance seemed to be primary reason for conviction.
How do you put brake shoes on backwards?
    JimmyB4
    JimmyB4
  • Who's Online   1 Member, 0 Anonymous, 616 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
