They retorqued the nut and put on Loctite back at 7K. Now at 13K they said they changed the idler arm and put on a new gear and nut. (not sure which gear yet) They said they found a lot of play in the arm and gear. How can that be when one minute everything is tight with no problems driving to Lowes, then when I go to leave the store is when it let go? I’ll get it back today and see what happens.
can't see your video for some reason...message me and maybe you can text it or wmail it to me...thx
I went to my original post and posted the YouTube video instead
That's basically what happened to my brother's truck. It's good 1 minute & then sloppy the next. Replaced the pitman arm back in Dec' & so far the steering is still good.
Please do..I'm very interested in how to get this permanently fixed.
I recently passed 9k miles (Flint built '16 SierraHD) and my steering is not as tight as it used to be. Here's a quick video I took, is this what others are experiencing?
Mine was rock solid after my gear box was replaced..now it's just like yours again. I'm getting very frustrated but do not want to move on to another truck. There's gotta be a fix for this. Please keep me in the loop if you get your back to normal. thanks
I'm hesitant to take mine in if there's not a proven fix yet, just temporary band-aids. Serious, how is this not a safety recall?!
BTW, it was really fun pulling my 30' travel trailer last weekend, steering was all over the road!
Ridiculous! It's simply unsafe. I've got little kids and they ride with me all the time. On the highway I'm white knuckling it so I don't run off the road. I don't want to give up my HD but I could probably swap my truck for a new 1500 crew with a 6.5 foot box. At least they have rack and pinyon steering. Not this digital assist stuff...It's disappointing. I really like my truck otherwise.
I'm really curious to see if this is still an issue with 2017 models. If it hasn't been fixed yet I feel like it might be. Can anyone with a 2017 hd chime in? I wonder if it'll continue into 2018 models seeing as how there aren't any significant changes.
Answered my own question with a Google search. There is indeed a PIT5501F. Can someone going to the dealer for this please ask them for a copy them upload it here like I did with 5501E?
My truck is completely stock. At about 9k I noticed the steering loosening. At about 11k I could turn the wheel between 11 and 1 and the front wheels didn't move. Went to the dealer with PIT5501D in hand. They said it had been superceded by 5501E. They did the locktite fix (5501E). It's been a couple thousand miles and so far so good. The existence of 5501F has dashed my hopes that the problem is permanently fixed. Now I'm back to waiting for it to loosen up again so I can take it back for whatever the most current PIT5501 happens to be. If someone could get their hands on 5501F that would be very helpful.
According to my service advisor that I spoke with today, PIT5501F is the same as PIT5501E with the exception that they removed the 2017 MY. I have not seen it personally so I can't verify if that is the only change(s) but I am currently trying to schedule mine for service for this and I will try to get a copy.
I dropped to a 1500. I think a class action lawsuit is in order. GM owes a lot of people compensation for the trouble we've had with these trucks.. including the financial loss realized when offloading the truck. The 1500 I have is not comparable to the 2500 but it sure handles well. Don't hang on to yours too long if you are not happy with it. It is depreciating by the day, a huge investment and GM doing squat. Report your concerns to the transportation safety dept. It won't do any good but it will create a file and time stamp of your complaint. Good luck.
Just to confirm that PIT5501F is in fact the same as PIT5501E with the exception of removing the 2017 MY. Here it is for your reading pleasure. On the 60 mile trip home from the dealer, the issue appears to be resolved.
#PIT5501F.pdf
#PIT5501F.pdf
#PIT5501F.pdf
#PIT5501F.pdf
1500 is rack and pinion. Car suspension. 2500 is torsion bar A frame Truck suspension. The only people having "trouble" are on the internet. Not everyone is unhappy. When you start vibrating or shaking you'll be back talking how GM suxs, etc. Good luck with your class action.
It isn't my first GM nor will it be my last. Unless you have access to every GM/Chev owner on the planet, you wouldn't know who is having problems. A fraction of owners find their way online to find out more about it or to see what others are experiencing. If this 1500 of mine shakes or vibrates, it too will go back to GM.
Point being ALL MANUFACTURERS have problems period. For the most part you can get good results not modifying crap that effects other systems. Not saying you have or did but the majority of complaints come after some kind of modification(lift, delete, re programming,etc.). Saying that GM or Ford or whoever need a class action suit doesn't represent all owners, unless you have access to all owners.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
