As the title states, this light came on this morning and my truck wouldn't start. After shutting door and letting everything turn off I got it to start, but the light was on my whole drive. After it sat at work for 10 minutes I fired it back up and light is gone. I've read about it before, and that sometimes it won't ever start again unless you go to dealer.
Any insight on this? Is it a possible battery issue?(I have HIDs hooked to the battery as well)
lol here we go.....check your battery cables and ground points....I've been going through this for months. GM will not help. Your truck could possibly shut off while driving, or start flashing codes, it will also whip the steering wheel out of your hands while turning ....watch out. Turns out this problem is more common than GM would like to admit.
What's on your keychain? There is something on it messing with the Fob that is setting off your theft deterrent system
Hmmm. Sounds crazy. It didn't come on on my drive home. I will monitor it. If it happens again I'll mess with the battery cables. I'm not gonna act surprised that GM won't help or admit to a problem...kinda like the vibration issues. I think there's BCM issues with my truck too. Having issues with fuel gauge accuracy (dealer replaced sensor in tank and nothing changed).
Only things on my key chain are a grocery store scan card, gym scan card, and 4-5 keys. 34k miles and this is the first time it's happened. I have 7k miles on it since it got 26k in repairs done from a crash.
I had it happen months ago, had it happen yesterday as well. Have also had issues with the truck consistently starting, and the steering wheel whipped out of my hands twice while driving in reverse. I've had the truck shut off, flashes multiple codes; service stabilitrac, service theft deterrent system, roll window down and back up, trailer brake system etc....my truck in particular is a wreck. I'll trade it in within a month hopefully . There are some other threads on here to search: steering wheel whipped out hand, trouble starting consistently, etc. Some members have had issues while driving, it's a lawsuit waiting to happen. I hope it doesn't take someone dying for the greedy, lazy assholes at GM to do something about it.
Mine has done that a few times, mostly during the summer months, chalked it up to the heat.  My horn would go off, in alarm mode, but no one was around it.  I would go to remote start it, no go.  Had the same message displayed, but was able to clear it, before rolling down the driveway.
it happens to me every time my truck doesnt start and the battery is dead (had a bad battery for too long and just kept jumping it lol) but after driving and turning the truck off it'd go away
  • 7 months later...
  • 3 months later...
On ‎9‎/‎14‎/‎2018 at 2:17 PM, KBoy420 said:
Has anyone ACTUALLY solved this?
Do a search for G218 ground some have reported that doing this simple repair fixed the issue. I get the Service brake assist and Stabiltrac together and it did not work for me but I never had anything worse than that nuisance alarm.
  • 9 months later...
3 hours ago, Linda Ragsdale said:
Has Anyone gotten any answers to this issue ? I’m having the same thing happen with my GMC . Please, any Anybody ! Thank you for your response .
Welcome to the site.
Any more info about your truck you can provide is always a great place to start for finding answers.
First question, original battery?
Stabilitrac and those issues are 99% solved by exactly what you posted. Takes like 3 mins to check it out. Never heard about theft deterrent issues associated with the g218 issue though.
I've had this issue with the Theft Deterent coming on with my 2015 Siverado 2500HD, replaced the battery, dealer replaced 4 of the 5 starter relays, also the positive cable on the battery and it still does it periodically! I can clear it! Then truck will start! Sometimes the Theft insignia will come on when this happens and will clear after starting it up again. Frustrated with this! Dealer said he'd call GM, no call back yet!
I had this happen just as you described, battery was under a year old at the time. I let it go, then after a while i started getting the random shut off WHILE DRIVING!!
I tightened the already tight cables and connections but still did it.
What finally solved my issues was adding another battery ground from the NEG to the ground bolt by the brake booster. This solved everything, which points to my negative cable being the issue, most likely.
I haven't replaced that yet, this is just temporary. I also did the ground bolt fix under the front left dash cover but not sure if that did anything towards all this.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
