Anyone use tailgate support bars?
Timmer, what do you want to use them for? It looks like they are one solid piece that you have to remove to close the gate, correct?
Correct. The bars are only used to support the tailgate (they take the load off of the cables) when using ramps to load/unload motorcycles, ATVs, etc from the bed of the truck.
That's what I thought. That's one reason why I'm experimenting with these: http://sinisterdiesel.com/i-20991687-merchant-automotive-tailgate-straps-for-2007-5-gm-trucks.html
These straps would just replace the cables and you can still close the tailgate.
I'm trying to see if I can modify one to "level" the tailgate instead of having it angle up from the bed.
Those look perfect! Are you saying they don't level the tailgate as is, though? I'm looking at replacing the cables so I don't have to worry about them snapping as I ride my motorcycle into the bed.
These replace the OEM cables and are exactly the same length. my tailgate sits too high when compared to the flat bed. installing these straps, the tailgate was exactly the same. I want to make a set about 1/2" longer so that the tailgate is a little bit lower.
Check this out. I was discussing this problem in another topic, check out these parts I found in post #25:
http://www.gm-trucks.com/forums/topic/187015-tailgate-not-sitting-flat-with-rest-of-bed-is-this-normal/page-2?hl=rider+tailgate&do=findComment&comment=1818730
Luckily my tailgate is level and flat with the bed in my truck, so I won't need that extender, but I'll try the straps.
Thanks!
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
