2016 ltz cc 6.2 wifi stopped working. I have a data plan but it just quit working. Tried several devices still nothing they all say they're connected but cannot download any data. Has anybody else had this issue because I really don't have time to go to the dealership for this? Wondering if there is an easy fix
Sounds like something on the OnStar side. If you can connect to the Wi-Fi that means that the hotspot in the truck is working. Wi-Fi can be connected without you having Internet access. It'd be the same as your PC being plugged into your router, but your home Internet being down. Still connected to the Network, just no Internet access. Are you sure that you called OnStar to get everything totally setup? I would definitely call OnStar and see if there's anything on their side first.
Thanks for the info. The Wi-Fi was working fine for months but just all of sudden in the past two weeks it's gone on the fritz one day it will work partially real slow loading.The next day it won't work at all just has the loading signal but won't load anything. I unhook the battery yesterday it seems to be working a little better today.
The Wi-Fi in my Denali seems to have a mind of it's own. Will not work consistently. called on-star multiple times and got no where. Time for a refund. Paid full price for minutes and now I see that Chevy has them on for half price. What luck!
I think they can do a system check and reset right from OnStar so just push the blue button.
They just set the WIFI password and name on my new one when I picked it up so they have allot of control.
Just to let everyone know unplugging the battery did help. Still has some issues but it's a lot better. Who knows how long it will last though.
  • 5 months later...
I have also recently had reliability issues with my wifi it was working just fine for months now it seems spotty. Sometimes its got a signal sometimes not,
wondering if I have an antenna issue ? My dealer has opened a case # and OnStar wants me to contact the dealer next time I loose signal.
They will drive a known "good" vehicle to my location to see if the problem can be replicated on the other truck. This diagnostic comes directly from GM so I will give it a try.
Do I have to pay for onstar to use the wifi? My onstar free trial just ended and my wifi doesnt seem to work anymore. I have it tethered to my ATT account.
You can buy any Onstar service individually. You can buy Wi-Fi by the month for $10 per month.
Go here:
https://www.onstar.com/us/en/plans-pricing.html
About 1/3 down the page > Compare Plans
I pay the extra $10 per month to tether the truck to my att data plan. Im just not interested in using onstar for anything.
Edited by Bikemobile
Yes, you can have the OnStar data (through AT&T) active without having OnStar. This is how my Malibu has been running for a while now and will do the same to the Silverado when the trial runs out in April.
Hi mbazinet,
We certainly recognize how this intermittent Wifi concern could be frustrating. If we can help in any way, feel free to send us a private message with your VIN, full contact info., case number and servicing dealership.
Kindly,
Anthony
GM Customer Care
  • 2 years later...
I have a 2017 chevy silverado and also have noticed the spotty reception . But I have also noticed that my cell carrier has also gotten worse in the last few months . I use my cell GPS all the time and have never had problems . But now as they try to move to 5g I lose GPS signal in places I have never lost before . I am wondering if the same thing is effecting my OnStar service . Being they are both satellite powered. The GPS and the OnStar signal.
OnStar is not connected via satellite. It uses AT&T towers.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
