How can I contact GM customer service?
When i worked for GM, there was an advisory sent out that a $100 deposit was sufficient, even for a factory order.
Dealers couldn't refuse to process an offer with a $100 deposit. Put an end to some predatory practices.
But a deposit is just that - non-refundable if you cancel, unless the dealer agrees in writing its refundable.
That's probably true. But, most of the time I've only ever been asked to put down a $500 deposit to secure a vehicle. I've never encountered any dealership that wouldn't do this over the phone and by credit card. When I call them I always ask for the sales manager, am very polite, and upfront about my offer. However, there are less than reputable dealerships out there with sleazy sales people. When I encounter them I take my business elsewhere. There's never any reason the get rude or nasty with people.
  • Replies 33
It makes perfect sense, don't spout bullshit opinion if you don't know what you are talking about.
He's agreeing with you and saying that what they're doing doesn't make sense on their end. Maybe you should actually read the post in context before losing it on the people trying to help and keeping your credibility. :)
They have clearly listed on some trucks that they have added stuff to no holds, does the truck you want have wheels/leveling kit or anything else done to it?
Sent from my XT1254 using Tapatalk
The OP was probably drinking when the dealer told him they wouldn't take a deposit then decided to get all assed up with Old Bay in drunken stupor.
Possibe. God knows i've done some odd and dumb stuff after a few drinks!
We all have. I learned early on to stay off Internet forums when I have had a couple.
I don't know about how it used to be but I do know now that Laura says and advertises no holds/deposits. I was there for 6 hours Friday because when I got there, they didn't have any non All Terrain or lifted CC slt z71's. I was there for about an hour in utter disbelief after waking up at 4 that morning and flying in from Atlanta. After walking around the lot looking at the all terrains, a guy that worked there drove by in a truck exactly like I was looking for. I asked if it was for sale and he said it was. I told him I wanted it on the spot. They had just taken delivery on 6 of them... they didn't even have window stickers or stock numbers on them yet.
This thread should be pinned as the strangest thread :-)
Thats odd, I bought this '16 in May from Laura and they took a deposit on my CC over the phone and held it for up to three days. They texted me the day before I was supposed to pick to up to ask what time I would be there. When I arrived the truck was detailed and waiting inside the service department - I was out the door in less than an hour.
Just curious, what makes Laura so special that many on here have purchased from them?
Looks like they sell a variety of new and used modified and lifted trucks.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 535 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
