I hated my Mayhem wheels so I went and bought Method NV in 18s. I should have bought these in the first place.
Looks good. How do you like the 275/70/18 KO2? You think a tune is necessary for overall ride/speedo correct?
Looking at this exact same tire in my '16 - same rear end and engine size as well.
Edited by ChevyRoofer
I love them!
I drove back from Texas about week and half ago with a 6x12 Uhaul VAN trailer. I would say probably 2500lbs. 13mpg at average of 72mph.
I took them out in the forest awhile back; they were amazing--great grip no issues. Definitely like them.
However, once I tuned the truck it was way better. With the heavy tires the tranny didn't know what to do--it drove like a dog.
I love them!
Thanks for confirming this for me. Have you tested it out at 85+ MPH?
Will be getting a tune from BBP then when I upgrade to the bigger tire/5100s.
HAHA, I'm sorry dude-- I should have continued that.
I get about 15-17 in the city stop and go. On highway I get 19; speed hasn't really affected much. I know the last time I went to Texas it was average 85mph on highway and the MPG were around 19.3.
I like those and was looking at them, also the Black Rhino Mint wheel, looks similar but has a little concave look to it.
Doesn't matter now though, dropping the truck instead...
truck-wheels-rims-black-rhino-mint-6-lug
  • 4 years later...
On 7/14/2016 at 8:28 AM, geswek said:
Not trying to revive a really old thread, but I read through most of your post and didn’t see. I assume these are 18x9, but what’s the offset? +18, 0, or -18?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
