New from Kansas City
Hello.. I researched various gm forums and decided to make a new home here. I recently traded off my 04 F350 with the infamous 6.blow engine. I spent so much time researching and repairing as issues came up. Now have an 06 Sierra with 13k miles and in great shape. Have a few issues to discuss and will address those in proper forums. Am sure my research experience with new ride will involve less headaches than the Ford.
Thanks, Greg
