ok whos got the quick answer... my 2014 silverado would NEED and can only use a 2014 denali cluster?
Yes 2014 Denali only
Correct. The ONLY exception to this and this is something that needs to be discussed via email as there is a TON of variables at play here would be those of you who have 2014-2015.5 Trucks but have already purchased the MVI CarPlay upgrade.
I'm so sorry, I emailed today. I just noticed the email only on weekends. I'm also very punctual usually but didn't notice this. I have a chance to get a cluster very cheap from a 2014 LTZ for my 2014 WT and wondering if you will do that along will the HMI programming and such for bigger screen.
If you could flag my email and even reply on weekend, I totally respect that and will wait: or I can email then. Just let me know what will work best for you. Thank you sir for the work your doing for us!
So I emailed a dealership asking about the cluster and it's availability , and I was told they are exchange only? You have to buy from a dealership and then they ship the old one back to GM? Does that sound right? Specmo says They are still backordered .
Edited by Txmade
No, thats not correct. At any rate we will have *ONE* 2017 Canadian (or export KPH) spec cluster here shortly if anyone wants it please email us ASAP as we don't think this will last long. Thank you !
Reminder we have ONE 2017 Canadian/Export KPH cluster in stock. We normally DO NOT stock hardware so this is first come first serve at a great price!
Basically, but you need to email GTPrix through his website with your VIN and he will tell you what will work. It's not as cut and dry as you would think.
Will this work in a 2016 sierra SLT I'm in Canada, can you pm me with the price and details please if still available?
If the swap for a SLT to a Denali Cluster, will the functions still stay as the same? As The mileage, lane departure, the park assist, front camera, etc???
Yes our custom programming allows for everything to function as intended as long as it's the correct hardware
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 654 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
