GM Is Gluing Its New Cars Together to Save Weight
muddkatt
The unconventional construction means the new Acadia is 700 pounds lighter.
Gluing a car together might seem like a dangerous way to reduce weight, but it turns out that the practice of using advanced adhesives to construct vehicles is not so new. The Boeing Dreamliner airplanes have used a kind of super-superglue since 2009. The epoxy resin and carbon fiber-infused plastic used to make the airplane's shell are two of the reasons why these aircraft have done so well commercially. They require less maintenance and, because they're lighter, less fuel.
Here's how it works: carbon fiber is treated at a very high heat and infused with epoxy resin. This creates a composite plastic that is tough and light. The end result of this process is something that looks a lot like black duct tape. Layers of this tape are laid on top of each other by a robot, often wrapped around a molding, until they've formed an aircraft component. Then, the new part is popped into an autoclave to harden further.
Now, General Motors is taking this idea and applying it to their cars. Though it's unclear if GM is using the exact same method as the Boeing Dreamliners, making use of intense glue and lighter materials creates a similar result. The toughness of the materials means that on their newest Acadia, GM cut down slightly on the amount of steel used in the cars construction. Though the difference in size may seem tiny (the new steel is about one human hair's width thinner than the old parts), it adds up to a huge difference in weight. The new Acadia is a full 700 pounds lighter than the previous version. This unburdening also means that the car is significantly more efficient. The new version gets 23 miles per gallon of gas, up from 18 miles per gallon before. It seems this superglue is nothing to sniff at.
source: http://www.popularmechanics.com/cars/a22310/gm-cars-glue/
This really isnt new. Thats how step side beds were held together. I have seen things on aircraft work that i would have never thought. GM can save weight with epoxy and duct tape
they could use inventive words.
I was one that screwed down hundreds of screws for many pieces of plywood wrapped in special paint for old kc135.
several of us exposed to a process got very sick.. it was a killer. New painted floors.
that stuff was primitive, and still worked..it was riding the pores of natural wood.
the new stuff has a carbon depth made from oil polymers to begin with..that is the "carbon fiber", the "epoxy resin" is the filler of void the polymer fiber demands, hence the strength. Premeditated bond down to near atomics.
they really could have invented words for their new stuff.
Sounds scary to hear carbon fiber (origin unknown) to epoxy reson (also never works for regular people stuff from a car store).
I'd trust it, as urethane is found in nature holding objects millions of years old.
man knows how to make it.
that leads to another point. Steel would be just fine if we were allowed the strength of the paint vapors in public (VOC levels)
whatever.. it is future, and their will be fails, assuming not many.
I found it interesting at how much weight that was saved by using the glue. Ford saved about the same weight on the F150's by switching to aluminum.
They didn't save 700 lbs by switching to glue. The new Acadia is a smaller vehicle, by a fair amount. That's where the weight came off.
Well the article mentioned nothing about downsizing....typical of the news articles today.
Yeah unfortunately no one bothers to get all the facts. As for weight savings at Ford, they may have shaved off the pounds but what no one will admit is by doing that they only got their trucks to weigh about what a similar GM truck weighs. The F-150 has been the fat kid since the 2004 redesign.
Speaking of Ford and the structural glue, here is a photo the Mrs found on FB.
13729146_634952203331065_295709998547181
Doesnt tell the entire story. Looks like it is in a tow yard. So it may have been cut open for occupant rescue
  • 3 weeks later...
There are only a handful of manufacturers that are any good at actually reducing weight and not cutting corners in the process. Mazda is maybe the closest to finding a magic balance but they don't have enough sound deadening. Look and the inside and out of a Mazda6 and you will be amazed at the quality for the price, then drive it with the radio off and some luster is lost quickly. Once they figure that out, they will be there. I've read they are getting better with the new CX-9. GM is doing ok, but it seems they over hype and under deliver. The 6th Camaro didn't lose as much weight as they seemed to imply, once everyone compared apples to apples (SS to SS).
Then they started going on and on about the Acadia....which is 3/4 the size of an old Acadia.
Ford, well you have seen the Silvy vs F150 commercials. Hope you baby it or have a good bed liner. Can only imagine if my brothers 300+ lb grill fell over in one like it did in my old 90 1500.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
