Need your help, my battery wont hold a charge. I have ran a load test and it shows a week battery also wont charge over 11.5 volts. I will take it to Walmart tomorrow to have them test it and replace if need. I haven't driving the truck much in the last year. I try starting it once ever 3 weeks. I connected a meter to test for a battery drain and it show 1.16 milliamps then drops to .34. What's the normal drain for a 07 chevy crew cab?
First off, personally I wouldn't take it to Walmart. Not saying that it's no different than going to Autozone to test it, I just for some reason can't trust anybody at Walmart in the shop part. I also wouldn't buy a battery form Walmart either, just keep hearing the batteries don't tend to last like they should. Maybe it's different for some, just from what I hear and have seen. But, if you said the load test showed it was weak and can't hold charge then sounds like you just need a new battery. Letting the vehicle sit like that will shorten the battery life among other things.
So I would just go to Autozone and have them test it. If you do need a new one then the Duralast batteries are good. At least for me they've always been good for me. I know the platinum one is a hybrid between a regular battery and an Optima.
After replacing the battery, buy a quality float charger like a Battery tender model and keep it connected when not driving
Sounds like a bad battery to me.
For what its worth I have a car that sits for extended periods of time with a ac delco battery from 2007.
My buddy has a AC Delco Battery from 2008.
Both cars fire right up.
I normally use Rural King Batteries because I buy a few a year and they are dirt cheap.
You will only find two manufactures of Batteries in the US Exide and Johnson Controls So I feel like buying either is a 50 50 crap shoot. lol
  • 7 years later...
Well after many years of haven a battery tender it won't crank now. I ohmed pin 6 and pin 14 and have 60 ohms. I thought my bcm was shot but now im not sure. All fuses and relays are good under the hood. Not sure where to look next.
silverado.docx
Edited by jaystone10
Well, if anybody was wondering what the inside of the fuse box looks like here it is. Cleaned it up and installed new fuses and it still won't start so I guess I'm off to buy another fuse box and maybe a bcm.
20230915_213202.thumb.jpg.5a6162bfd1205c2ad4280bde1cdd7bc4.jpg20230915_212221.thumb.jpg.04a0c0c639d51ea09bab4b6f10dfae89.jpg20230915_211637.thumb.jpg.fef7cd656c7cd692579c2284814be274.jpg20230915_220510.thumb.jpg.a612f60a580ba52261f12cbd877a732f.jpg20230915_220504.thumb.jpg.d9c20258bbfdacf0ab79f6cee392e528.jpg20230915_220410.thumb.jpg.cd7f306a0fea1cbe0e3c9c91556068d1.jpg20230915_220402.thumb.jpg.5525b69c3234744d8083d6772046b4f3.jpg
  • 5 months later...
I know this is an old post but just keep in mind that any battery will only last between 1-5 years at most. If it last longer, you're just asking for it to straight up fail out of nowhere on you.
I would recommend using something like AAA (if that's something your area offers) to get a battery as it's around the going rate, has a 3 year warranty, and they come out to wherever you are located to test/replace it.
Past this, I hope replacing the BCM or Fuse Block fixed your issue. I would've done more testing myself like jumping the battery directly to the starter to make sure the battery and wiring/etc is okay, to rule out those items - but that's just me lol
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
