My condenser only lasted 10k miles. On backorder. Is there tsb for the condenser?
I have the same problem. 2015 Yukon Denali. Condenser failure. They told me national backorder, no idea when they will get it in. I have taken to harassing GM on Twitter. This should either be a recall or a class action lawsuit.
It has been running about 4 weeks to get the newest designed part in. No need to start suing until GM stops picking up the repair bill. After that, file away.
Oreilly auto has murray condensers which would probably be just as good as a delco. I know people want the dealer to do it but if you cant get parts maybe its an alternative? and they show them for 147 dollars not 300. Murray makes a lot of a/c components so if your a diy person id go with that.
Edited by ericw
It's been 5 weeks. Nothing.
The Oreilly in my area told me that no store in the Houston area has a murray condenser as they are also on back order... that was what I was going to do but the dealer was the only place I was able to find in my area that had a condenser.
Warranty customers with a rental get top priority to get them out of the rent car on GM's dime.
When I brought the car in, they gave me a rental for a few days and then once everything was diagnosed they said that the warranty wouldn't pay for me to keep driving the rental while I waited for the part. I had to return the rental and pick up my Yukon. Been waiting ever since.
You should have told them to pound sand. They will get the rental back when the AC gets fixed. In the southern US, if the AC is not working, the vehicle is out of service.
Could everyone that is having condenser issues please report the problem to savercars.gov? You can call or fill it out online. They are the ones that investigate recalls. GM corporate will do absolutely nothing to help with this. Once you report your issue to safercars.gov the issue will be in investigated on the continuous issues with the condensers. Thank you! I filed mine today!
Is that just for "safety" issues? Why would nhtsa care about you being warm in your car? Unless you make a case that the defroster uses your ac to dry the air so if your defroster doesn't work then it's a safety issue.
Edited by ShamrockShooter
No it's not they handle the complaints for these as well. I did mine over the phone with a representative. But you can also to it online. I thought it was just for safety issues as well at first.
I think I'll give them another week or so in good faith to fix mine. I'm at 4 weeks now
Just joined the forum because of this issue.
March 21, I purchased a 2014 Silverado LT Doublecab with 87,500 miles on it. Salesman told me that it needed a condenser and it would be $1400 and it would take three days to get it done. No problem, $1400 added to price of truck
Picked up truck March 24, nice and shiny, ready to go. Salesman handed me the keys. I drove off. First couple of days it was very cool out, so no need for air. But third day it was warm, so I turned on the air. It blew hot.
Went back to dealer, talked to salesman. "Oh, didn't service dept tell you the condenser was on back order?"
Long story short, it's been 9 weeks today since I bought truck, and when I called dealership today, same story: it's still on back order.
My previous Silverados, a 2002 and a 2006, were excellent trucks that I put a whole lot of miles on (250,000 on the '02 before I traded it). But right now, I don't know that I am too pleased with GM or the dealership where I bought the truck. It's a known issue and they are trying to act like this is the first time it's ever happened and they just don't know why it's still on back order.
This is a terrible first post, I know, but I drive 70 miles round trip to work and having no air really sucks.
Edited by arkiehotrods
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
