CK156 on 33s or 35s??
CaseysLTZ
This is my buddies truck...4" BDS lift with 285/55r22 Nitto Trail Grapplers.
FCA1C571-4A7C-4D18-8C51-E63A907201D7_zps
D92B0132-F469-43DA-AAD7-D99CCF153C4F_zps
9219A3E5-4DD2-4420-A0B5-91F02BE0F3A1_zps
E4D74EE4-D8B6-470F-B3BD-A355651C6861_zps
0FE7782A-11B8-4AC2-899D-94E52AABD245_zps
340BE54C-02E1-49B3-B0C7-2C61D76324D5_zps
I ran 'replica' wheels on my Range Rover - factory wheel design in a 22". Looked sweet, never had in issue. I've heard stories of wheels that peeled or that weren't true, but I bought from a reputable dealer in California and they warranted against defects. They looked sweet. I will say the only reason I went replica was because the stock wheels only came in 20" and I wanted 22". With the wheels above, I'd buy them from a dealer as they aren't too expensive and you can get 22".
Where did he get that grill?
22" factory rims powdercoated with 33's soon to be 35's. I am trying to upload a pic but it keeps on saying the files are to large to upload. PM me your email address and I will send pics.
