Installing Kill Switch
EspoMan
Hello guys. Just recently purchased a 2016 Silverado LT with the 5.3 V8. I will be staying with my sister for a while and she lives in a very shady area of town. I want to install a Kill Switch on my truck but with all the modern technologies in these trucks, I don't want to mess anything up. What do you guys recommend for installing a kill switch on my truck?
I believe Onstar protection may be a good solution. They can track and turn off your truck remotely if stolen.
Yeah I do have OnStar but I want to stop it from being stolen in the first place.
You have a much greater chance of someone stealing the rims and tires or the tailgate than taking the whole truck.
I don't imagine that many people will give up their methods of installing a kill switch on an open forum, but I might be wrong. I would suggest asking your dealer or a good mechanic in your area.
+1 on Muddkatt's comment. Rims, tires, and tailgates now a days are a lot easier to steal and resell than an entire vehicle that then has to be stripped down. I'd invest in some good locking lugs, or maybe even get 2 sets so you have 2 different special lugs per rim, and a lock for the tailgate so it can't be removed. Not just the OEM lock that prevents it from being opened but a lock that goes on the passenger side hinge that will keep it from being able to be removed.
seems like it should be called an overkill switch these days. From what I understand most high end or newer car thefts they just roll up with a truck or flatbed and tow you away.
Now a days a driver can hook you up and bolt without even needing to get out in like 1 min or less.
This of course does not count for thugs and holigans but they are more likly to steel your stock rims lol or just smash the window to go through console etc for loose cash. Most common criminals or thugs will not the have kind of equipment to steal a late model gm. If they do have the equipment it won't matter if they really want it they will just tow it.
Thanks for the replies guys. I'll look into securing the wheels and and tailgate.
These trucks come factory with an immobilizer. If they tried to "hot wire" it it would not run. Also they use a resistance based start sequence on the second starter and second accessory wire which a common thief would not be able to replicate.
Bottom line is as others said most newer vehicles will be taken using a tow away method so an aftermarket 2 way alarm system with digital tilt would be the best method of protection as long as you are in range or if you have added dronemobile or smartstart to it you would receive a notification on your smartphone.
Sent from my SM-N930V using Tapatalk
  • 3 years later...
24 minutes ago, Reginald55 said:
Here in Texas onstar have been disable before truck leave yard.
I was going to say they need to look at what's going on down there with these trucks.
Yeah, a kill switch, or you put a bracket or something like that around the ecm that would take tools to remove (that they wouldn't have, because it's mostly just plastic clips keeping it in place normally).
