Ha - I was wondering when someone would mention the "flares". I actually meant those emergency glow stick type things not a true flare as that could get interesting if a flare was ignited under the hood!
Usually called chemlights. You could def store them in the box but I would recommend against it. Especially if you live in an area with harsh winters as the temp swings will eventually lead to its degradation. It's better to keep a few of those in the cab of the truck.
Great storage option for tools or emergency stash of stuff that's not going to degrade with shifts in temp.
Sent from my Nexus 6P using Tapatalk
A member here posted this on another thread, it's a simple and great idea. Storage box for 90's pickups
Okay I found my next thing to do.
  • 3 months later...
Part number anyone?
Part number anyone?
i can't find it right now, but i posted the part #s in another thread. Those boxes are old and came in the 96-99 tahoes/suburbans.
Quart of oil
Funnel
Rags
Duct tape
Spare fuses
Bungees
ICE AND BEER
Ice and beer wouldn't be great with the heat, unless you can find a $500 yeti cooler that fits there lol
I can see why - those 20 year old GM bins are $60 plus on eBay......... Do you have a pictures showing that group 24 box fits?
These tough bins / trays / boxes by Akro-Mils part # 33105 fit the space. Would be great for jumper cables, quarts of oil etc. The vertical slots are for dividers.......... Come in several colors.....
http://stores.ebay.com/Zoro-Tools/_i.html?_nkw=33105+box
Edited by Krusty
Can you fit a quart of oil in that box?
With some of these trucks you might need to store 5-6 qts of oil in there lol. Its a pretty good idea though. I would like to keep basic hand tools, safety wire and safety wire plyers, along with first aid kit and other things you might need in an emergency.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 1 Anonymous, 561 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
