How many lbs of boost and what fuel are you using? Great numbers
9.5 pounds and 93 octane.
Ahh thats why. You didnt run out of fuel qith that much boost?
nope, I guess he tunes Whipples with 10-12 psi with the stock fuel system all the time.  I think I should be able to do 500whp without running out of fuel, so I can probably do headers and be pretty much maxed out.
Now, These are SAE corrected numbers.  it was 45 degrees out and the observed numbers were around 510/520 before the correction.  So I don't know if I'm maxed out now, or what.  I'd rather not be maxed out and risk going lean than risking it trying to squeeze every last pony out of it.  So I'm probably not going to do headers any time soon at this point.
The tuner was really impressed with the numbers. He's a Procharger and Whipple dealer so he wasn't really excited when I told him I went TVS, but now he's considering this blower for his truck since the price is so low and it made good numbers.
6,600 miles.
Nothing new, just some pics from last week and this weekend I reinstalled my Roll pan because it came un-taped in the corners.
I'm really thinking about getting the New Corvette though, So I might only have this a couple more years.  We'll see.
Edited by qwank
19 minutes ago, qwank said:
here's the roll pan pics
Man I really like that!  :thumbs:
Btw, I got the procedure from JL on how to get the left minus right rear ambiance signal (it's really simple)  but my attachment folder is full here. If you would like to see it on the setup screen message me your number and Ill text a picture to you.
What is the wheel/tire and drop combination on this truck? It looks perfect for a daily!!
Belltech 4/6 drop and 22" Mrr T228 wheels
I finally got this thing to the track last night. Ran a best of 12.81 @106.
Here's a video of a 12.89@106 with a 1.7 60".
  • Like 4
I'm running 20s right now with 305 Nitto 420s
Looks good! Love those rims on these trucks
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 420 Guests (See full list)
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.     Here's a version of the L87 recall with the p/ns for all the parts needed.    RCRIT-25V274-7075.pdf   Note it shows 19420611 and 12740076 with an asterisk to a footnote "Use the VIN and the GM Electronic Parts Catalog (EPC) to determine which part to order if two or more part numbers are listed for the same part, as it may vary by vehicle options."
    • Looking for advice from this group. Took my flawless 2020 6.2 TB to an unnamed shop for routine rear brakes and oil change. Tech forgot to put oil back in after the full service and needles to say, destroyed my engine.  It’s all on their shop video so they are responsible.   I had my Chevy dealer do the analysis and they confirmed its compromised and said engine replacement. The manager said they only get GM reman engines from GM with full 3 yr warranty and the one they would put in is not same as what’s they are swapping out on 21-25 for recall.    I am looking for advice why that would be a different engine because obviously I had the good 6.2 year and replacing it has my concerns with that recall for 21-15   Also what’s the pros and cons of accepting the engine swap vs telling the shop that bricked the truck to pay up so I buy a new truck. I’m concerned about stigma resale eventually if I just decide to get rid of it after the swap or other issues showing up after the swap out.
    • Just looked up my records.  I've never gone over 5000 miles between oil changes.  At 46K miles, I have 10 oil changes.  I hope that will help.  I also installed the disabler last year.  I've still had a few times when it didn't seem to engage (which I can tell because the start stop feature kicks in), but for the most part, I think it's working.  For some reason, GM did not include the number of cylinders running in the information screen like I had on other models.  In my Cadillac, it shows me when it's running on 4 cylinders on the fuel milage screen.  I can't find that on my '21 Denali.
